Username: Saqeeb9000 Post Number: 1885 Registered: Oct-07
Wednesday, January 30, 2008 - 17:48 GMT ok last night i scan 118.7 and i am getting few channles for 118.7... but i am not getting any international channels How come?
Username: Cubiche CUBA,
CUBA
Post Number: 51 Registered: Jan-08
Wednesday, January 30, 2008 - 17:56 GMT DO YOU HAVE GOOD SIGNALS ON ALL TP.?
Username: Saqeeb9000 Post Number: 1889 Registered: Oct-07
Wednesday, January 30, 2008 - 17:57 GMT no..
Username: Xtrawest BC
Post Number: 136 Registered: Nov-05
Wednesday, January 30, 2008 - 18:01 GMT which receiver u got?
Username: Saqeeb9000 Post Number: 1890 Registered: Oct-07
Wednesday, January 30, 2008 - 18:03 GMT nfusion
Username: Kirankumar Kenya
Post Number: 1198 Registered: Oct-07
Wednesday, January 30, 2008 - 18:36 GMT Sada, have you checked your settins
Username: Saqeeb9000 Post Number: 1898 Registered: Oct-07
Wednesday, January 30, 2008 - 18:41 GMT yep african .. i got 119 dish on port 2.. what i did is also put 118.8 in port 2 and scan it .. and wanna make clear that i got few mosly english channels for 118.8 dish.. i pressed the info and it says anik 118.8 dish.. so that means i am getting 118.8 dish... but signal quality is low...
CUBA
Post Number: 52 Registered: Jan-08
Wednesday, January 30, 2008 - 19:01 GMT sada 119 should be on port 1
Username: Saqeeb9000 Post Number: 1900 Registered: Oct-07
Wednesday, January 30, 2008 - 19:04 GMT i got 91 0n port 1 119 port 2 148 port 3 82 port 4
Post Number: 1200 Registered: Oct-07
Wednesday, January 30, 2008 - 19:04 GMT Sad, try disconnecting all birds and hook up 118 7 only directly and scan and see what you get.post results
Username: Saqeeb9000 Post Number: 1901 Registered: Oct-07
Wednesday, January 30, 2008 - 19:05 GMT i need a ladder...
Post Number: 1201 Registered: Oct-07
Wednesday, January 30, 2008 - 19:28 GMT what you guys need to do is locate the switch at ground level,so it is easy
