Bronze Member Username: Deptrai_cachonPost Number: 15 Registered: Jan-08 | I just bought vs ultra i tried to get dn signal.. loaded new bin, set up everything . scan, blind scan .. I still didn't get any channel. (it fail) .. do I have to manually input the keys for dn ? Any sugession guys .. Pleassse Help me |
Gold Member Username: NydasPost Number: 7515 Registered: Jun-06 | You seem to know what to do. Inputing of keys manually at 0101 ID can't hurt. Did you check the signal strength and quality in the Antenna setup? |
Bronze Member Username: Deptrai_cachonPost Number: 16 Registered: Jan-08 | yeah , the signal is good (s)87% (q)87% -- but i'll try to manually input they key . see what happen . thanks .. Nalin |
Bronze Member Username: PlymouthQuebec city, Quebec Canada Post Number: 11 Registered: Jan-08 | try my post https://www.ecoustics.com/electronics/forum/home-video/437519.html#POST1415743 |
Silver Member Username: KirankumarKenya Post Number: 981 Registered: Oct-07 | ken, as a matter of interest could you post your settings and hardware? |
Bronze Member Username: Madflea168Post Number: 98 Registered: Jan-08 | you have good signal and quality, but is the sat locked in the sat menu set up? if you got the correct set ups, you should have channels in, whether the bin working or not, as long as you have the right set ups, you should always able to scan the channels. since you don't have, perhaps you need to check the set up first then worry about the keys. |
Silver Member Username: KirankumarKenya Post Number: 982 Registered: Oct-07 | correct |
Bronze Member Username: PlymouthQuebec city, Quebec Canada Post Number: 14 Registered: Jan-08 | Hey guy my viewsat autoroll all the time just on dish whit good set-up and good bin, reset all and by hasard i create a new sat whit 110w and blind scan this one and Dish come up immediately , i think this a virus, because when reset all you erase not all setup in box |
Bronze Member Username: Deptrai_cachonPost Number: 17 Registered: Jan-08 | yes, I can get to Setup screen .. I tried to setup everything I could.. for dn - echostar 7, 119 when it scan it go up to 87%, but it still Fail ... this is frustrating !! |
Bronze Member Username: PlymouthQuebec city, Quebec Canada Post Number: 16 Registered: Jan-08 | create a new sat whit 119w in CHANNEL SCAN and blind scan this one |
Bronze Member Username: Deptrai_cachonPost Number: 18 Registered: Jan-08 | hey guys, when the bird is scanning .. is the sat icon should have some receving signal ? mine it just show "three" percentage bar ! |
Bronze Member Username: Deptrai_cachonPost Number: 19 Registered: Jan-08 | plymouth, how do i do that ? create new sat whit ? sorry i'm new to this |
Bronze Member Username: Post_manPost Number: 35 Registered: Nov-07 | Plymouth what do you mean when you say that you create a new sat? Do you mean to say that you are adding a new satellite? 110 & 119 should already be listed in your receiver.If not please explain what you are talking about. |
Silver Member Username: Way2smartHttp://desifta.co.nr/ Post Number: 636 Registered: Oct-06 | yaaa omar he means scan the sat and get the channels and u should be good to gooo |
Bronze Member Username: PlymouthQuebec city, Quebec Canada Post Number: 19 Registered: Jan-08 | Go in installation menu, enter, 0000 pin code,channel scan down arrow ,and on folder+ enter and just to left enter on little dish, now you are in the satellite menu, right arrow for select userSat-1, go to motor and select usals,up arrow an put 119 and arrow down for west,ok,exit and save, exit,exit and save,go to blind scan, scan start OK when finished save and press button SAT on remote and select Echostar 7 . Good Luck KEN |
Silver Member Username: KirankumarKenya Post Number: 985 Registered: Oct-07 | Ken, when you go to set up what do you see ? if you post that we can help otherwise you are never going to get your system up and running.also haw many dish do you have and do you have a switch. post this info,because without it everybody is guessing to try and help you. |
Bronze Member Username: PlymouthQuebec city, Quebec Canada Post Number: 20 Registered: Jan-08 | i know but on my viewsat this the only think work for repair my box only with Dish , i think this a virus (bad bin) |
Bronze Member Username: Deptrai_cachonPost Number: 20 Registered: Jan-08 | ohh I hoook the LNB cable straight to the receiver...and AV cable to the TV ... (with out switch) I have 1 satelite .. thanks for your help guys.. i'll take the pic from tv screen.. and upload so you guy can see later, i'm at work now .. |
Silver Member Username: KirankumarKenya Post Number: 996 Registered: Oct-07 | if that worked then the solution is simple,you have the wrong setting.post your setting later and we will set u up |
Bronze Member Username: Deptrai_cachonPost Number: 21 Registered: Jan-08 | African , i don't need the switch if I have 1 reeiver and 1 satelite right .. ? I just need dn that's it ... or i have to from sat to switch(119) and switch to receiver ?? I'll post my setting tomorrow thatks for your help guys... |
