CS4000
Username: Panamio1
Post Number: 9
Quick question, if someone can help. "Greatly appreciate if. Is any else experiencing trouble with the loading of CSpro. I use the proloader 2.4, I have the null cable, and for some reason it does not show any progress. Any input or response is apprecieated. Thanks
Username: Silver1123
Mexico, DF Mexico
Post Number: 448
Dissconect the lnb cable.
Reset your box from back
should work
Username: Coolsatfv
Post Number: 29
Alex, make sure that you choose the right computer PORT before transferring data. (The best way to check is going to Administration Tools, Computer Management, Device Manager if you'r running on WinXP)
