What BIN for Pansat 2500 converted to 2700 ?
Username: Nyc_alien
Staten island, Ny Us
Post Number: 101
Hello all,
whats the BIN for PANSAT 2500 converted to 2700 box. The file at FTATALK says its not for the converted box.
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1398
try at desifta.co.nr..or dssworld
Username: Nydas
Post Number: 7448
[link removed]
There are 5 Conversion BINs listed.
Also only conversion BINs at:
http://public.box.net/2500_full_kit
Always unzip before use.
Username: Nydas
Post Number: 7461
bluegillbilll asked.
Username: Bluegillbill
"nalin i have a mulistar pantec ultra could you tell me how flash it back to life because it will not turn on no power.
Answer: If there is no power, you have to jtag. If there is fuse inside near the power cable entry or near the switch, you could check it first.
Username: Zibruno
Post Number: 46
Hi Nalin i converted 2500 to 2700 and have one problem.Once i finished the conversion I wasen't able to access parental control for some reason.If i would enter 0000 it woulen't accept it and also tried 8282 but no luck. Someone told me to shut off reciever from the back and to turn it on which i did. But now all i see is b75 across the display screen. Dosen't stop and go to on. What should i do?
Thanks
Username: Nydas
Post Number: 7465
bruskie: What BIN have you installed? What was your original receiver?
You have installed but you do not seem to have gone on to section E of the instructions. There is still a lot to do
Username: Zibruno
Post Number: 47
i didn't get a chance to insatll bin because i wasn't sure it i had to wait for receiver to say on.
Username: Nydas
Post Number: 7472
bruskie: Download and unzip the full_kit11A. Spend some time reading the instructions. You either do the whole conversion and installation properly or you do not start at all. There are no short cuts.
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
In case you have difficulty getting the latest BIN, it is available here.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest CS_241T_lightning file
The latest jvvh_241 files for Pansat or Fortec remote '" for DN fix
The newest jvvh_241 files for Anik3 scan '" for DN fix
Some of the older versions and jtag files are also included.
The full kit is in full_kit11Azip. Unzip into a new jvvh directory.
The 240version and 241 version conversion files are available separately as well.
Username: Luv2meet
Post Number: 23
Nalin, is the 241 bin still working... Bev is down as of 8:00 tonight at my end... can you please help confirming. tia
Username: Nydas
Post Number: 7474
I cannot scan BEV, but reports are that BEV is down on BIN 141.
Whilst people were conjecturing DN ECM, I saw BEV new ID 0907 keys change this afternoon about 4.30 pm Eastern and was expecting it.
If I hear of any old file working, I will report.
If you have the 226T and want to test - it is a long shot.
Username: Luv2meet
Post Number: 28
thx Nalin, we found out that bin jvvh 213 is working.
Username: Domy
Post Number: 93
209 is working too
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 595
be careful with the 215 conv bin...it is a killer bin..!!
Username: Nydas
Post Number: 7480
If you are looking for th eold working conversion BINs jvvh_213 and jvvh_209 try downloading
jvvh_213_and_209.zip at
It is a temporary BEV only fix
