Pansat 2700 convertesd new bin working...
Username: Vinnyc
Mb Canada
if you a pansat 2500-2700 converted this is the bin try it and it works. jan 17 08 jvvh_pansatremote_239 bin. you can find it at dssworld...... its good dishnetwork working again.
Username: Halo
Toronto, Ontario Canada
Post Number: 329
also you can find that bin + others at www.dish-keys.blogspot.co* (remove * with m)
Username: Vinnyc
Mb Canada
problems downloading my receiver 2700 converted everytime there is a new bin. I know how is done becasue I program my brother in law's receiver.
anyone have the same problem?. If you do can you let me know what to do thank you...
Username: Destine0429
Quebec Canada
Post Number: 387
I got the bin at ftahq.com (FUTUREFTA)
Was just wondering if it keeps bev working while it's a fix for DN. It's the
jvvh_Pansatremote_239.zip
Is this good? Thanks
Username: Batjc
Post Number: 93
yes Julie... and CS 239T is already out too...
you can use either one
Quebec Canada
Post Number: 388
Thanks Jeancarlos
Username: Mike73
Post Number: 38
Ive tried to download the 239t bin and it says cannot open serial port access denied any suggestions?
Quebec Canada
Post Number: 389
Have you tried other serial port #s? I know that was my problem.
Username: Mike73
Post Number: 39
no I havn't but really not that sure of what im doing anyways how do you change the serial ports.Thanks
Quebec Canada
Post Number: 390
When you open your updater, it gives you the option on the top left.
It should say COM SETTINGS and under that it should say COM1. You can click on that and change it up to COM4. Try each one. On COM2 click Write bin. on COM3 write bin, on COM4 write bin. If any of these work, then rememebr which one for next time ;)
Username: Mike73
Post Number: 41
Tried that Julie says same on all
Username: Dfvader
Post Number: 7
What receiver are you using steve? Is you cable a Null or Straight? Have you ever wrote a bin before on that receiver?
Username: Laurad
Post Number: 86
I have dowloaded the CS_239T lightning, and I am unable to get some channels like HGTV, I have Echo3/9 and 7. My screen goes to black when I try to do a Power scan or tp on Echo7, should I change to jvv239? Thanks LauraD
Username: Laurad
Post Number: 87
I just downloaded the CS239Tv1_lightning and it works well got all channels back. LauraD
Username: Borinick
Post Number: 107
HI every body should i use this bin for my vortex 7700 its already bin clone to 2700 already it was working fine but should i used this Bin jvvh239.zip is it safe for this box?
Username: Famf555
I just loaded CS_239Tv1 and the channels don't seem to last. They begin to go snowy with the picture going in and out. Also, some ppv read "no signal". anyone else having this problem?
Username: Nydas
Post Number: 7324
CS_239T is very defective. CS_239Tv1 is better.
jvvh_239 is very good.
I am about to try the jvvh_240.
There are some more BINs out there for 240 version, but I do not see Chancy's CS_240T_lightning yet.
Username: Kayahalha
Montreal, Qc Canada
hi,how to unzip file.
Username: Jaye50
Post Number: 60
nalin have you tried jwh_240 yet.....if so are there any benifits in using it instead of jwh_239....as always thank loads.....
Username: Nydas
Post Number: 7349
"I am about to try the jvvh_240. "
I said that yesterday. In another thread, I have posted that I give it 10/10.
