JVVH Bin 239
Username: Asharfi
Post Number: 1726
All FLU and Pansat 2500 working .. enjoy
Download files from Upload
Username: Webjohn
Post Number: 8
is this true?
Username: Dude123
Post Number: 1839
yep...also available at [link removed] enjoy!
Username: Mriaz
Hi any one download this file for flu (converter 2500 to 2700) and also for clone. Please response
Username: Johnnynitro
I download it and will test it now. Thanks.
Username: Nydas
Post Number: 7276
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
In case you have difficulty getting the latest BIN, it is available here.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest CS_237T_lightning file for BEV fix
The latest jvvh_239 files for Pansat or Fortec remote '" for DN fix
Some of the older versions are also included.
http://public.box.net/2500_full_kit
The full kit is in full_kit9Bzip. Unzip into a new jvvh directory.
The 237 version and 239 version conversion files are available separately as well.
Username: Lucia
Calgary, AB
Post Number: 481
it works great!
thanks to the coders.
Username: Asharfi
Post Number: 1727
All channels are working ... I have tested this file ... enjoy ...
Username: Lucia
Calgary, AB
Post Number: 483
my bad, thanks to you too AV. ;)
Username: Batjc
Post Number: 87
hey AV i have a original 2500 converted
and last bin was a Chancys
is ok to load this one?!
Username: Faras
to nyda
i downloaded,from public box.net as you suggest "The latest jvvh_239 files for Pansat or Fortec remote '" for DN fix " my pansat 2500a converted en 2700. the remote control is not working;i used a 2700 remote to change channel and to scan. DN didnt work; after several hours there is no green light, the box is may be dead.
-is it because the bin 239 is not safe
-do i need to jtag my box
thanks
Username: Pannu16
Post Number: 737
i saw this bin which is on name of SAIF BIN 239, is that good or no!!
Username: Tscon
Post Number: 82
Anybody care to upload the file to yousendit.com
use any fake emails.
And let us have the link? It's just don't make any sense to register all the time to new site for just 1 file..
Thank you.
Username: Tscon
Post Number: 83
OK, I got the file and do it myself
here is latest 239_CS bin
http://download.yousendit.com/BA6958656CDF753B
Working good, enjoy.
Username: Tachance1
Southern Ontario, ON Can
I have tried the CS_239 bin....didn't work for me on my converted pansat 2500 clone...receiver just kept rebooting.
So I loaded the jvvh_239....it's working great for Charlie BUT now the '0' on my remote isn't working which means I cannot access the password protected menus. Any ideas?
Username: Viruscauser
Leesburg, Georgia
Post Number: 750
Tachance1, if you used the jvvh_fortec, try the jvvh_pansat - and visa versa.
Username: Bewolf
Post Number: 27
Working here...thanks!
Username: Tachance1
Post Number: 7
Abby....thanks for the suggestion....now the remote is functioning properly and BEV and Charlie both working great!
Username: Faras
second message
to nyda
thanks
Username: Jmill1948
Chester, Va Usa
Post Number: 1094
pr if no power u must jtag...........
Username: Nydas
Post Number: 7300
The conversion CS_ and jvvh_ BINs for converted boxes are safe.
If you have light, try reverting to the 2500 state and start afresh. If there is no light, you will have to jtag. You can jatag directly to converted state using conversion jtag BINs.
Username: Nydas
Post Number: 7301
The latest CS_239Tv1_lightning file for BEV fix
The latest jvvh_240 files for Pansat or Fortec remote '" for DN fix
The newest jvvh_240 files for Anik3 scan '" for DN fix
The full kit is in full_kit10zip. Unzip into a new jvvh directory.
The 239 version and 240 version conversion files are available separately as well.
