SV file Q?
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1388
im confused some say its out some say its not...i rather jsut ask then check..so is SV 4000 bin out yet? thanks
Username: Saqeeb9000
Post Number: 1616
did u check it at
http://desifta.co.nr/
Username: Nydas
Post Number: 7332
Sonicview 4000 is BIN 193
Sonicview 1000 is BIN 288
Username: Way2smart
Http://desifta.co.nr/
Post Number: 530
Satgrl its in the sv file section in desifta
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1390
but nalin that is only for local right ? does it fix international? on DN
Username: Nydas
Post Number: 7336
It says for locals, but it fixes DN
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1392
ok thanks alot;)
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1393
i had to get SV bin from totalfta becuz everytime i would go to desifta it would say internet explorer cannot display page and it woulr shur down...lol..i tried AOL but still not work..ill try tomorrow to fix my profile in it and all;)..thanks sada..ahre bhai aap to moderator hai desifta ki..aap ne bathaya he nahin...lol good luck with site
Username: Way2smart
Post Number: 531
thx satgrl
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1394
welcome
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1395
thanks guyz SV is up and working...lub u
Post Number: 1619
see smart i told u site is not working good.. it gives u erorr message,
Username: Way2smart
Post Number: 533
wearied i ll try to fix it up
Username: Way2smart
Post Number: 534
what browser are u guys using?????
Post Number: 1623
microsoft int exp 7
