Pansat 2700 A not working
Username: Vedgebill
Post Number: 12
Hey! I have a Pansat 2700A and I try to download the bin 240 but in my GT rom loader everithings is fine except the progress bar. The progress bar stay at 0%. What is the problem?
Username: Charjam
Post Number: 300
where did you get bin 240 the latest bin i knew was 239 and it is working fine
Username: Vedgebill
Post Number: 13
I get the bin 240 here : http://future-fta.info/index.php?stage=1 But where can i get the 239?
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1385
billy what wir/cable are u using? try BL updater
david get it here
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1386
billy get bin 239 at ftabins*net under pansat section
Username: Vedgebill
Post Number: 14
What is that mean? I use a Usb to Rs232 Cable!
But i nedd to put a adapter female to female at the end of tjis cable!
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1387
oh i c..alright make sure u unzip ur files
Username: Vedgebill
Post Number: 15
yeah I know i have to unzip the file but my progress bar stay at 0%.
Username: Borinick
Post Number: 104
He billy is youre cable is the wrong cable because it happen to me and the wright bin is 239.
Username: Borinick
Post Number: 105
you could the cable in radio shack Billy.
Username: Vedgebill
Post Number: 16
ok but where i can get a good cable i didnt find one on ebay because all the cable are male and my pansat is a male too! if someone can show me where i can get a good cable?
Username: Jwl1
Post Number: 71
Was your receiver (back) switch in the right position?
Username: Nydas
Post Number: 7362
Pansat 2700. Latest BIN is BL87 240.
Parent site: http://www.future-fta.info
Usb to Rs232 Cable is a straight cable. You used a F/F cable which is a straight cable. You need a NUll Modem cable. Best is to go and get a DB9 M/F null modem adaptor. That way your current cable on its own will have one type of pin out and when used in series with a null adaptor it will have the other type of pin out.
Did th eUSB to serial come with its own CD? You need to first deinstall the automatic installation done by XP and reinstall using the drivers on th eCD.
You need to check in your computer's device Manager the setting of COM port for the USB to serial and make sure it is COM 1 or COM 2 and select the appropriate com port in the installation of BIN onto your receiver.
summary: You have correct BIN and from correct site. You have correctly unzipped. You do not have correct cableing. You may not have correct COM port setting.
Best of luck.
