Cw600p down on dish
Username: Brucester
Post Number: 1062
cw down on dish working good on bev will post when new bin comes out
Username: Leines
Post Number: 62
what bin are you using for bev currently bruce?
cheers
leines
Username: Brucester
Post Number: 1063
cw600p bin 168 all up and working on bev you can get it at crazyfta dot com
Username: Leines
Post Number: 63
i have that bin.. but im am not up.. that is the 01-11 bin correct?? i got it from complete...but still scrambled channel.. been waitin for a roll.. seems like right keys as well...
Username: Leines
Post Number: 64
Bell ExpressVu (0901) [Last update: Thu. Jan 17, 3:25 PM CST]
86: CD 7F 03 26 BF 4A FE DD 87 C2 47 7F 10 FE 44 F2 New
96: 4A AB 77 FB AE A0 9B 55 E2 55 54 F1 F7 70 BD E4
Those are the keys i am using as well..trying to get channel 400 tsn... with bin 1.68 installed...
Username: Brucester
Post Number: 1064
tury your box off from the back what 10 sec then turn it on that is the same bin i got and im geting ch 400 im geting all bev ch put your tv on vu2 ch152 this will help it roll faster and you have the right keys check your settings to
Username: Leines
Post Number: 65
settings havent changed, it was up two days ago.. went down last night with the key change, and then never came back with manual input...
i turned off at back... turned back on... on channel vu2.. still getting scrambled channel... letting it roll..waiting for tv..
will report back
Username: Brucester
Post Number: 1065
try to inabble the patch f1-000 on the remote till you see on the tv patch inabble
Username: Leines
Post Number: 67
also have that enabled... im lost... the box is working cause i get the free dish channels like homr 100
Username: Leines
Post Number: 68
also still getting free sirius on dn....
doesnt make sense...
Username: Yakovaki
Post Number: 192
leines
my advice is to put on channel nbc boston 287 on 91w
wait like 10 mins for fast roll and it should work from there
Username: Yakovaki
Post Number: 194
sorry that is 280...not 287
Username: Frobi
Guelph, Ontario Canada
Post Number: 153
CW600P Have Nimiq 1 @ 91 degrees with 1.68 bin. Quality and strength are over 80%. Keys are ok, still no channels, just "scrambled channel". Any help?
Username: Leines
Post Number: 70
yea still having the same problem and sheel... even while on nbc JB
Username: Brucester
Post Number: 1069
do a factory reseat then do your settings scan sat91w enable the patch i live in ottawa ont and bev is all up on dish watching the game sens and car hope this works for yous
Username: Brucester
Post Number: 1070
dish is down no ppv or p0rn only about 100 ch are working on dish whating for new bin
Username: Brucester
Post Number: 1071
waiting
Username: Frobi
Post Number: 154
I got it going. I had to do factory default, install 1.68 bin and rescan. Works good. Try it lienes.
Username: Brucester
Post Number: 1074
that is what i told leines 2 post up glad it worked for you
Username: Frobi
Post Number: 157
Thanks Bruce. Hope it works for leines
Username: Leines
Post Number: 72
Ill give it a try.. i was just watching some of the random higher dish channels that had hockey on... any idea why i need to rescan when that bin was working when i first installed it?
Username: Mrskullz1
Brooklyn, New York
Post Number: 789
there is a 1.69 bin out now by the way :-)
Username: Brucester
Post Number: 1076
all up and runing good you can get the bin from crazefta dot com
Username: Brucester
Post Number: 1077
sorry it at crazyfta dot com
Username: Dude123
Post Number: 1845
[link removed]
Username: Leines
Post Number: 73
Yea i tried all the stuff bruce.. no luck.. then i found the new bin late last night shortly after my message..and was good to go....
why u pushin crazy now bruce and not completefta?
Username: Brucester
Post Number: 1083
i can do more at crazy but i like complete there fast and friendly and do not need my help and crazy is just starting out and need a hand and i needed a place to call home
Username: Leines
Post Number: 74
fair enough.... i went to complete on ur advice, and it seems to have the files very quickly...
Username: Brucester
Post Number: 1084
yep yep you are right and now you can get them at crazy enjoy
Username: Ambangisssss
Post Number: 13
hi bruce...is der a new bin out now for cw600 }regular?
Username: Brucester
Post Number: 1086
yes you can get it at crazyfta dot com
