Sonicview fix
Username: Princealbert
Post Number: 25
ftaforall has new sonicview fixes for b3v
Username: Nydas
Post Number: 7190
New BINs out for
Sonicview 1000
Sonicview 4000
Sonicview 8000
Go to
[link removed]
[link removed]
[link removed]
[link removed]
Username: Djibo
Post Number: 29
1- Nalin, is the file posted on DssTester .com is the wright one ( dsstester-SV4000_V0192P beverly FIXED.zip). Is it for Bev and DN
2- Should I execute the factory bin before to upgrade form the SV4000_V0188P_BEV_AR_FIXED.bin to he 192 . Because it the second time fore me (in the first time maw SV 4000 was new ) thanks
Username: Nydas
Post Number: 7196
Upgrading from one BIN to next in Sonicview does not require factory BIN.
I do not know about the file V0192P at dsstester, because I do not normally go there for files. The file is the latest for both DN and BEV fix, but is no improvement over V0191P for Dn. It was released mainly as a BEV fix.
for DN 185P, 187P and 191P are all working fine, except that each higher number is an improvement over the lower number in terms of freeze fix.
Username: Book77
Post Number: 123
192 is working great for BEV no more delay or freezing.
I love my SV 4000 it is a big step up from the CaptiveWorks 600S.
The epg and usb flash drive are awesome.
I recommend this receiver to anyone in the market
Username: Nydas
Post Number: 7205
In Canada, it is less than C$140
Username: Nydas
Post Number: 7215
There is a 288P fix for Sonicview 1000 and
a 193P fix for Sonicview 4000.
[link removed]
[link removed]
SV4000_V0193P Charlie local FIXED
C/P
Hello everyone,
Here is the SV4000_V0193P Charlie local Blackout FIXED for SONICVIEW SV-4000.
enjoy
SV4000_V0193P
*** Charlie local Blackout * FIXED *
NOTE:
- Do a hard reboot (power OFF-ON using rear switch) after every update.
Ciao
SaCoDi
Team FFA
SV4000_V0193P Charlie Local.zip (1.07 MB)
Username: Jayson
Post Number: 80
I\\'ve been told that SV 4000 bin SV4000_V0193P is working......all channels open.......
Username: Ynkr77
Post Number: 49
confirmed bin 288p and 193p for Sonicview are up I own these 2 and are fully wide open.
Username: Nydas
Post Number: 7222
It seems that amongst the FTA group of receivers, Sonicviews are the only receivers up for DN!!
Username: Silver1123
Mexico, DF Mexico
Post Number: 444
nfusion is also up. All channels up on DN and BEV
Username: Kukkudo
Post Number: 60
CNX is up
Username: Rtap
FL
Post Number: 1675
SONICVIEW FIXES FOR MODELS 1000 & 4000 AVAILABLE AT
WWW.CRAZYFTA.COM
Username: Lucia
Calgary, AB
Post Number: 470
wow that was fast! i want sonicview now.
haha.
