Screwed Up Channel Listing-Need Help
Username: Jryevols
Little rock, Arkansas USA
Post Number: 54
I am still running on Pansat 3500sd the old file and everything runs great.Last night when I turned it on and went to EPG for the channels the date had changed tp April 5th and I couldn't find any channel listings. I went into user setup ,but it will not allow me to change the year that is set at 2002 or the time. Can anyone tellme what may be the problem?
Thanks
Username: Rtap
FL
Post Number: 1671
menu>user setup>scroll to time hit ok> change time/year then hit ok to save.
