Need Help!!!
Username: Cricket674
Post Number: 178
I have a converted Pansat 2700 (2500/2700) with the CS 232. It was working amazingly until now... The channels with the W's(Channel names that start with W) stopped working... What should I do!!! Any help appreciated!!!!!
Username: Nydas
Post Number: 7185
It has something to do with your LNB, etc. You could post some more details of the setup.
Alternatively, the 237 BIN is out and you might want to upgrade to the new BIN and then see what happens when you setup everything.
[link removed] for BINs or from
http://public.box.net/2500_full_kit
Username: Nydas
Post Number: 7189
Of course, you could try switch off at the back and switch on after 30 seconds. It might work.
Username: Batjc
Post Number: 84
i have the same prob as his... all my locals from puerto rico stop working i even installed the newest bin and nothing all channels working perfectly except those
could it be a TP change?
if could where can i check it
Username: Nydas
Post Number: 7192
If it is a TP change, do a "power scan" or "Blind scan" and you will get ALL the current channels.
