Transponder question
Username: Onphyre
hi,
i have a viewsat extreme pointed at 110. For transponder 12559 which has all the hockey/sports channels, it does not get a good signal, but all other transponders including ppv's work on 110 with a good signal. any suggestions?
thanks kindly.
Username: Rtap
FL
Post Number: 1642
check your alignment on dish.if not check your switches,cables,etc..
Username: Scabz
Knoxville, Tn Us
Post Number: 297
Check your tp freq. My dish was in the right place but my freq. wasn't right. I just figured it out today.
Username: Onphyre
If I get better quality cables, do you think that may help with my quality strength? I have a wire from my dish to my house, then a wire from my switch to my tv wall, and then another wire from my tv wall to my receiver. Suggestions?
Username: Onphyre
Post Number: 7
If I run the cable from the diseqc switch directly to my receiver, do you think that may help with quality strength?
