New member Username: El_chePost Number: 1 Registered: Jan-08 | hello, can someone please tell me which .bin to load for BEV on my pansat 2500 clone converted to 2700, and where to find it. thank a lot. |
Gold Member Username: NydasPost Number: 7085 Registered: Jun-06 | For Pansat 2500/FLU new conversions and converted to 2700 Use only on converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones In case you have difficulty getting the latest BIN, it is available here. Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest jvvh_235 files for Pansat or Fortec remote The latest CS_235T_lightning Bin included These three files are also available separately for those who do not want to download the full kit http://public.box.net/2500_full_kit The latest ECM of 13th January, requires that you use the 232 or 233 BINs for DN. You will only get half the BEV channels on 232-233 and the other half on 235. These have been posted separately in Conversion_232_233.zip file. |
New member Username: El_chePost Number: 2 Registered: Jan-08 | thanks alot Nalin and have a nice day |
New member Username: Sparky123Post Number: 3 Registered: Jul-07 | I have a Fortecstar Lifetime Ultra and its not working. Can anyone help, or anyone has a bin file that i can load. Thanks} |
Gold Member Username: NydasPost Number: 7093 Registered: Jun-06 | sparky123 : Did you read ANYTHING in this thread? The answer is there just two posts above, in full details. |
New member Username: El_chePost Number: 3 Registered: Jan-08 | hi, I'm having Scrambled or bad Channel on my pansat clone converted with CF 235T, on odd and even channels. any idea how to fix it? thx |
Gold Member Username: Saqeeb9000Post Number: 1545 Registered: Oct-07 | what ever is the new bin it would be posted at [link removed] after downloading bin what ever is posted there u channel still not working u have to wait for new bin... |
New member Username: El_chePost Number: 4 Registered: Jan-08 | thank you sada. i read that some people are habing problem with the new 236, is there a new fix for that? |
Bronze Member Username: Vyizder_zomenimorPost Number: 40 Registered: Aug-06 | I found one called Jvvh_Pansatremote_236 that fixes the remote issue when using an original 2700 remote. Works fine so far. |
Gold Member Username: NydasPost Number: 7162 Registered: Jun-06 | Conversion BINs: CS_236TV2_lightning is defective. Use jvvh_236 - either the Pansat Remote or the Fortec Remote version. The 232 and 233 BINs also work with a little freeze up now and then |
New member Username: FeltPost Number: 3 Registered: Dec-07 | use cs_226T_lighting to get bev back |
Bronze Member Username: Cld_canadaPost Number: 12 Registered: Jul-06 | Nalin, Like u said I tried 232 but it does not work on BEV. I have converted pansat 2700 (clone) |
Gold Member Username: NydasPost Number: 7166 Registered: Jun-06 | New BINs for conversion fix the DN and BEV A/R. For Pansat 2500/FLU new conversions and converted to 2700 Use only on converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones In case you have difficulty getting the latest BIN, it is available here. Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest CS_237T_lightning file The latest jvvh_237 files for Pansat or Fortec remote http://public.box.net/2500_full_kit The full kit is in full_kit9.zip. Unzip into a new jvvh directory. The 237 version conversion files are available separately as well. |
