Experiencing HIGH WINDS no signal
Username: Ptaha
Post Number: 57
Hi can you please tell me whats up?
The box says "searching signal"
We have very high winds here today...
do i have to readjust the settings?
Username: Joed
PLATINUM VIP MEMBER
Post Number: 64
Very high winds could be tree swinging in front of dish, dish moved, lots of cloud cover blocking signal.
Username: Ptaha
Post Number: 58
i have a vs xtreame and it the right half cyrcle it doesnt show any signal..
is it gonna be hard to get the sygnal back?
Username: Ptaha
Post Number: 59
i got vs extreame and in the half circle on the left doesnt even show anything... i got 110 and 119...
Username: Tapeman
New York City in-HD, NY
Post Number: 2135
I noticed no signal if yo use old bin
What bin do yo have?
Username: Ptaha
Post Number: 60
bin from the 22nd
should i try the new one?
Username: Tapeman
Post Number: 2136
Yep
Try 080114 but not off totalfta
Username: Ptaha
Post Number: 61
where would you recomend it from?
ftatalk
Username: Donnie1973
Post Number: 2583
no signal or quality?
Post Number: 2584
maybe u have the sat line plugged in to the wrong place on the reciever?
071222 workd fine
Username: Tapeman
Post Number: 2138
thetotalfta has it on front site
But use at your risk
ftatalk maybe ok too
Username: Tapeman
Post Number: 2139
DN disables signal upon ECM
It is one of the hardware issues I discussed
that yo never bothered listen to
It's a bin issue
Post Number: 2585
no its not dear, i am watching that bin now. this is why i dont listen to u. Because u are wrong... again
Post Number: 2586
put ur multimeter on it...lmao
Username: Tapeman
Post Number: 2140
Whatever yo say
Post Number: 2587
signal is ur connection to the lnb... thats all. go do some more..."tests"
Username: Tapeman
Post Number: 2141
What are yo gonna get your Mama for valentine?
Username: Ptaha
Post Number: 62
didn't work....
Username: Rtap
FL
Post Number: 1640
hey brother dantetn whats up.been missing in action.lol
Post Number: 2588
u have lost the connection to ur lnb i think. Either the cable is plugged in to the reciever in the wrong place OR at the dish? Check the cable. King isnt a very bright person, i wouldnt listen to him. He will have u chasing bins all over the place.
Post Number: 2589
yeah, been hiding a little. Reading a lot at dsstester. How ya been?
Username: Ptaha
Post Number: 63
nothin showing
Post Number: 2590
right... check ur cable connections. That is most likely ur problem. is it the signal or the quality that is 0
Post Number: 2592
king, is that u or ur dad? I know u guys dress alike... its hard to tell the diff
Username: Ptaha
Post Number: 64
no everything worked fine until tonight... there are winds here.. i don't is it the cable? maybe antenna is not set properly cuz of the wind?
Username: Tapeman
Post Number: 2144
No
But my dad knows how to drive a fork lift
Let me know if he can be helpful for immediate transportation
Username: Ptaha
Post Number: 65
what do you guys think?
Post Number: 2593
lol, i bet he can...
DAVID, IS THE Q AT ZERO OR THE S???
Post Number: 2594
man. i asked 3 times. it will help us help u
Username: Ptaha
Post Number: 66
it's showing:
S 39
Q 00
Post Number: 2595
u are not connected to ur lnb good for one thing, but maybe it moved in the wind. U would have to turn it a little to see
Username: Ptaha
Post Number: 67
whats lnb?
Username: Rtf
Post Number: 31
david you have 2 threads going on the same subject, don't do that. In your other thread I said ckeck LNB also Check you antennae settings ie. LNB type....most likely Standard/ Switch ports 1-4 if you are using one/ LNB freq. .... 11250 most likely/ if there is an option for LNB power make sure it's ON.
Username: The_messenger
Post Number: 102
dantetn if you chip in we can buy this equipment for King Tapeman for valentine.
BTW I wouldn't make fun of that picture above.
It could be his wife or maybe his mother.
That is the only reason I can think why he has that picture.
UploadUpload
Username: Drmunna
Post Number: 249
DAVID
ITS WIND AS U SAID wait to get it normal,,,its just that.
Username: One_eye_jack
Post Number: 204
Yes David the wind may have knock your dish out of alignmemt. But don't wait the
wind will not bring it back.Put your coat on and get your tools out.
Username: Ptaha
Post Number: 70
Hi
Thanks for so many replies. I checked all the connections in the morning and nothing changed.. So I tried moving the dish manually but it seems to be firmly in place.. Could it be that the winds moved it so much that i don't have the signal, yet i can't move it at all with my bare hands?
Username: Tapeman
Post Number: 2153
I don't think it is wind if it was bulted good
I'll try a coax cable straight from LNB to receiver before moving dish
use 081226x this I know it works
Post Number: 206
David
It don't take much to knock the dish out of alignmemt. When you tried to move the dish with you bare hands did you try side to side and
up and down? I don't think your hands are as strong as the wind.Take a small level, check the mast on both sides to make sure that the mast is level.Also how is the mast secure? Check to see if your mast came loose.
Username: Pulp_fiction
Post Number: 1024
Maybe Save u self some time go grab the factory bin reflash the box and see if u have signal and quality If u still have nothing then start screwing with the dish. Factory bin will not decrypt of course but it provides a much more stable receiver for scanning and testing signal strength.
Username: Kingsatman
NYC, NY
Post Number: 146
Factory Flash According To Pulp Fiction
