Viewsat ultra wont start up
Username: Cash_money
I have a viewsat ultra, and I was updating the files when after about 10 minutes of the system not reacting, i turned it off to reboot. I now have a dashed line going across the LCD screen. Any suggestions
Username: Satgrl
Post Number: 1362
u need to load the factory bin ok...
How do i do that? its not recognising the usb.
Username: Nydas
Post Number: 7094
You will have to use the serial cable supplied and use the appropriate loader.
Get the files, the loader and instructions from
[link removed]
[link removed]
[link removed]
Username: Blierso
Post Number: 19
Go to the factory support site, you'll find everything you need.
[link removed]
Username: Blierso
Post Number: 20
[link removed]
