Pansat 3500 problem
Username: Jon55
Hi I have a problem with my pansat receiver. I lost my signal today and when I go to the Antenna Setup menu I have a strong level reading on all three satellites but I have 0% on all three for quality. Before I would have a quality reading for Echo 7. Can anyone please help!
Thanks.
Username: Kirankumar
Kenya
Post Number: 904
have you checked your settings ?
Username: Opie
DEEP SOUTH
Post Number: 33
Need more info, What dish, LNB, switch, etc... are you using.
It could be a diseqc switch gone bad, or the dish moved during a storm, or if it snows there, there may be snow on the dish.
Let me know what equipment you're using
Username: Jon55
I did a factory settings and still get the same thing. When I change the TP to [2] on the echo 7 it changes the quality level to 70% but it chages itself back to [1]
Kenya
Post Number: 907
jon,
can you post your settings so we can help?
Username: Jon55
What settings do you mean?
Kenya
Post Number: 910
go menu satellite settings
Username: Jon55
I went and cleaned the snow off the dish and it worked. Thanks for the help people!
Kenya
Post Number: 915
you are welcome
happy viewing
