Nfusion setup
Username: Scabz
Knoxville, Tn Us
Post Number: 246
How do you hook the cable into the nfusion. Is it usb that can be used hooked up to the router or just a straight cable line ?
Username: Abj
Post Number: 497
do a google search..
there is plenty of info out there.
Username: Ftaruler
Mexico City, DF Mexico
Nfusions Nova has two connections: the usb, that is to be used with an external hard disk, and the network cable. The network cable should be connected to the Internet router.
If your regular cable dosent do the trick, get a crossover network cable, sells for $10 at any radioshak.
Also, sometimes if you connect the nfusion to the ups, there is no signal, so if this happens, connect it directly to the wall outlet.
It heats too much, its normal.
Be sure to take a very thin plastic film covering the receiver before using.
It works great.
Username: Extremex
Post Number: 123
ummmmm.....There is no USB connection on the nfusion.
Username: Vittu
Post Number: 105
use a patch cable straight in the back of NFusion and other end to router/modem. There is NO USB port in NFusion unless Roberto got one in his :-)
Username: Saqeeb9000
Post Number: 1299
its a network cable same cable that connects your internet modem to your computer (white colour) ethernet cable cost about 10 bucks..
Username: Ke5aqn
Post Number: 3104
My Nfuson is not here yet but, All descriptions I read about the nova do not include a USB connector.
As I understand it you send the video back to the host computer via the Ethernet connection for DVR use.
http://www.nfusionusa.com/
I can provide more links if needed..
Username: Ke5aqn
Post Number: 3105
I would like to add that it will be cool as he-- if you can use a usb external hd for DVR...but, that is on the dreambox not Nfusion
Username: Ftaruler
I stand corrected Extremex.
I meant the rs 232 connection.
Username: Ke5aqn
Post Number: 3112
aww ok Roberto I see how it is I provided links to back up my answer
