Can someone confirm VS Xtreame working?
Username: Ptaha
Post Number: 49
Btw thetotalfta.cm does not remember my password and username... and does not have the bin posted on the front page.
totalfta.cm has an option of downloading from front but the forums are unaccessable.
Where do I download?
Is there lots of freezing?
Thanks
Username: Silvermir
Post Number: 23
I dont trust totalfta.cm
but u can download the latest bin for xtreme from:
http://ftaforall.net/forums/
Username: Joed
PLATINUM VIP MEMBER
Post Number: 62
Totalfta is hijacked. Go to THETOTALFTA. All userids and psswords work there.
Username: Ptaha
Post Number: 50
if the total fta is the original and legit. how come it doesn't remember my pass and login?
Username: Madflea168
the new bin did not seem to work on my xtreme
Username: Koko_wawa
Post Number: 196
DAVID go to this trusted site for downloading new files [link removed]
then go to file section and look for your box type.
Username: Jojogun
Fairfield, CA United States
Post Number: 354
At another site a mod has stated that the viewsat coders are experiencing difficulties and the files they released are temporary. They will release the better files later. c/p below.
Posted January 4th, 2008 12:44 PM IP Reply with quote Edit Post Delete postViewsat Coders are having difficulties so they relesed temporary fixes. They said they'll release the good ones soon. If you're having problems, you can switch back to old bins and watch local channels.
Username: Tapeman
New York City in-HD, NY
Post Number: 2024
totalfta was hacked several weeks ago I don't trust them by all means
But there is a great possibilty hackers were able to hack into the forum data that holds user names and passwords creating same belivable atmosephere taking away actual forum data without succefully snitching its domain name
So is it the domain name or forum data that got hacked
Use caution and look for clues
