Nfusion bin ......
Username: Saqeeb9000
Post Number: 1115
Yesterday, 04:23 PM
therepo
Administrator
Hexxagon Champion! Breakout Champion! Snowboard Challenge Champion! Canuck Rally Snowmobile Champion! Dune Bashing In Dubai Champion! Aero Chaos Champion! Spider Man. Dark Side Champion! Battleship Champion! BMW Driving Champion! Pingu Sports! Champion! Yeti Sports 1- Long Shot Version Champion! Death Junior II Champion! Bend it like Beckham Champion! Agent 420 Champion! 3D-Stereogram Tetris Champion! 7up Pinball Champion! Ad-Break Toilet Dash Champion! IceSlide Champion! Zapper Champion! Zelda Mini Game - Cucca Hunt Champion! Aga Maze Champion! Agumaze Champion! Inuyasha - Minute Game Champion! This means war Champion! Hop `till You Drop! Champion! Angel Run Champion! Armada Assault Champion! Ice Age Part 1 - Scrat Jump - Level 2 Champion! Swing N Slide Champion! Ice Age Part 1 - Scrat Jump Champion! Incriminati 2 Champion! Mumu Champion! Animal Keeper Champion!
Nfusion - V1.42 (final)
Release Version : "1.42 IPVR 0.77" (combined upates in order)
updates on 15 Dec 07 (this bin will be placed on update server)
IPPVR
1.1 IPPVR PC application
1.2 How to guide of nFusion IPPVR
2. Extend EPG updates from both 110,119
3. Faster EPG scrolling
4. Dish/Bell SID renumbering option
5. SID remap on none dish/bell satellites
6. Faster DHCP(LinkSys WRT54GS confirmed to work)
7. STATIC IP setting option
1. SW21 + DPTwin + Third Lnb.
2. Free Satellite sellection on DPTwin, DPQuad, LegacyTwin, LegacyQuad.
3. EPG Update on USALS
5. Usals stalls
4. TP Update (ANIKF3 KU 118.8W)
5. memory alloc fail on bin update.
1. DishPro(Legacy) Lnbs bug fixed
2. missing channels fixed
3. DishPro500 Plus confirmed(110, 118.8, 119, 129)
4. EPG updates on 118.8, 129, etc.
5. Faster Ch, Fav Edit.
6. Alternative language supported
7. 22KHz switch control enabled.
1. IPPVR related
1.1 No REC blinking(Exit button to Remove)
1.2 Channel Benner with Info button
1.3 Scheduled Recording along with wish list.
2. Auto lock adult channel after scan
3. Radio Channel order by Number after scan
4. Signal & Quality Status Display on Channel Banner.
5. Autorolling & Emulation Diabled by Factory default
6. 3 Sats with DP34 confirmed(2 STBs Min)
7. ESP alt audio (spanish) blue button then ok selects
8. sirus scans fixed (pending iks) to be opened and song info
side note on ippvr (it will continue to improve)
it was released yesterday.at ftaview.... is it same thing as dec 15 bin... ipvr version 1 ...is not working good with what ever i have in rec... its recording for few minutes..but i can not play it...any one have same problem.. post here
Username: Birdwatcher
Post Number: 612
F.uck NFusion, this is satellite tv not internet tv. for all of you asking for help with NFusion, find your shiot somewhere else. There i hijacked this thread.
Username: Chicken_zackary
Post Number: 45
Username: Yakovaki
Post Number: 129
stfu u fools get a life
sada i have no problems recording for extended periods of time on that same file of dec 15
it may be a connection problem or something else
i am using a router and have made my nfusion static and also made my computer static
try playing around with your router settings
goodluck
Username: Ke5aqn
Post Number: 2703
David,
Stop that the Nfusion is a bad choice over a DREAMBOX yes but it is still a FTA receiver. It uses the internet to get updated data just like your receiver does. It just does it a diferant way
Post Number: 1125
ok Jb i know how to make my rec static..there is option on menu... but make ur router static..any help with that...
+ do you ipvr version 1 or or you using 0.75.. + which windows media player works to play the files..
also as i posted the above link.. i tried to do an upgrade using remote.. i don't think any thing is changed.. its same ...it says released on dec 16..
Username: Yakovaki
Post Number: 130
fta is the dreambox down on iks? and bins? but up on aux? can u have a bev and dn card in it"? or only in 7020?
Username: Yakovaki
Post Number: 131
hmm i have .75
ok if your upgrade does not work on the remote then i can help u easily i think
it means there is a connection problem
are you using the net adapters? netgear?
Username: Ke5aqn
Post Number: 2705
JB
I do not have my dreambox here yet all i know for sure is they in the forum say it is working.
Username: Yakovaki
Post Number: 132
iks?
cuz if iks is working i will get a couple to fool arond with...price is excellent
Username: Ke5aqn
Post Number: 2708
they are and have been working all the time so they are worth getting to watch tv
Username: Yakovaki
Post Number: 133
so dreambox works on iks at the moment is what you are saying????
that is great and it is worth getting...the learning curve is a little higher than say a viewsat or pansat...but im sure with some time it will come easy
Post Number: 1133
ok JB.. its downloading fine.. but it says release date is dec17 whatever.. you said ipvr ver 0.5..may be that's the problem .. i have 1.0.. where i can download 0.5
+ u stil didn't answer my question to static option
Username: Yakovaki
Post Number: 134
no i have .75
i am guessing your problem is with the net adapters
do you have a direct ethernet? or net adapters?
i got mine from nfusionforum.com
[link removed]
that is the direct link to the file sada
try it out
i have not bothered updating to 1.0 havent even heard of it
i guess i will wait a bit since this works with minimal problems
sometimes has problems on my laptop do to wireless disconnections
Username: Yakovaki
Post Number: 135
ok static stuff should be in your router settings (on your computer...)
basically you have to go to your settings and change the different internal ip's to static that way they never change
the problem with the nfusion is it likes 100(last 3 digits of ip) its the 1st in the series usually
so if your other computers are trying to take 100 it will have interference
Post Number: 1137
actually i have direct conncetion.. with router.. i found ver 1.0 at ftaview.com...
Username: Yakovaki
Post Number: 136
ok if you have direct connection then its router settings and not the net adapters
good
what kind of router???
dlink? lynksis???
Post Number: 1140
dlink
Username: Yakovaki
Post Number: 137
ok what version?
Post Number: 1142
WBR-1310 > Wireless G Router
Username: Yakovaki
Post Number: 138
ok lets see....do you know how to access your router settings???
type in your browser 192.168.....etc....
put pass in etc....
then in the settings do the following:
click on setup
then on the left panel click on network settings
go down to the ADD DCHP RESERVATION box
type nFusion in the computer name box and press enter
it should bring the MAC address up for the nFusion
add 100 in the last box of ip address
click enable
and it should add it to the list on the bottom
do this for your computer as well after to make that ip static too
put 101 for your computer or something
then in the nfusion ports put the same thing as you have in the router (using your remote on the nfusion)
let me know if it works
Post Number: 1144
ok i will try tomorrow and give you the results .. thanks for help...
Username: Extremex
Post Number: 109
Guys.
IPPVR.EXE is 1.0 (that is the file on the PC)
IPPVR 0.75 is integrated into the 1.41 bin
IPPVR 0.77 is integrated into the 1.42 bin
Both need to be used with the IPPVR.exe 1.0
Username: Yakovaki
Post Number: 140
if not sada....go here and look at manual
http://www.dlink.com/products/support.asp?pid=474&pv=96&sec=0
may need to update firmware to 1.04
take care my friend
n good luck
