Help for co*lsat 6000
Username: Domy
Post Number: 74
i put the new key and still dont work
Username: Space_invader
Andromeda M31
Post Number: 345
did you upload the new bin 157? if not, download it and install it to the receiver... make sure the autoroll is on and wait a few minutes for it to roll...
Username: Domy
Post Number: 75
i did
Andromeda M31
Post Number: 346
here: (register first)
(official)
[link removed]
(other)
http://www.ftabins.net/showthread.php?t=19462
Username: Klondike_kike
Post Number: 7
Username: Domy
Post Number: 76
new bin manual key dont work
Andromeda M31
Post Number: 349
which satellite are you trying to see? try to turn off the receiver for some time and start it again... which channels (if any) can you see...
Username: Lalusingh
Post Number: 10
i can get some of the cartoon network and other free channels in 200's no hbo or nothing else i have 157 bin
Username: Domy
Post Number: 77
im in BEV
Andromeda M31
Post Number: 350
ok, domy... read this copy/paste:
"bev was down on my cs6000.. but i just entered the new keys manually and all is up and working fine. My channels went scrambeled a couple times since i entered these.. but i put it on a ppv channel (vu #) and did a hard shut off ( flick switch off and on, on back of receiver) and channels came back on aftter a few seconds.."
text/plainUpload
Keys.txt (1.4 k)
so... try to turn off the A/R and insert the new keys... then put a ppv(vu#) and turn the receiver off from the back switch and then on and see what happens...
Username: Ke5aqn
Post Number: 2366
make sure autoroll is off as well or the receiver will change the keys on you!
