Viewsat frezzing up every now and then.....
Username: Bjcrisp6478
Post Number: 95
any one haveing this problem???? i got an xtreme and it dn......any help....thanks
Username: Ke5aqn
Post Number: 2242
https://www.ecoustics.com/electronics/forum/home-video/422451.html
Username: Guanajuatos_best
Post Number: 102
REALLY???
Username: Nydas
Post Number: 6439
The easiest first try is to load the factory BIN, followed by latest, and use either a good channel list or do a Blind Scan if your receiver allows it.
Once it is going, it helps to keep the autoroll, autoTP and closed caption off.
In particular, if you are using channel lists, keep autoTP off.
Username: Ke5aqn
Post Number: 2252
I would add also always install a fresh satfile after you put the new bin in the recever. We are getting reports of receivers losing data during the updating process in the satfile. So after you upload the bin upload a new satfile useing same loader it takes a matter of seconds..
[link removed]
for the satfile
Username: Chicken_little
Post Number: 315
Most bins still freezing Upload
Username: Chrisduclo
Post Number: 124
this is from the official futrue irc channel
c/p
News: --->>> Blacklist Releases:!2700 !2800 !3500 !5000 !6000 !250sm !9000 !9200 Team Blacklist working on more stable solution.VS fixes:!vsplat !vsextreme !vsultra !vspro . CNX:!patch CNX seems to be working with DN only. Files are on a temp bot for now.ALL FILES/PATCHES ARE FREEZING set by [-_-] on Sun 23 Dec 2007 @ 10:07am eastern time
Post Number: 125
yesy i know this site is for pansats, but i am pretty sure that the same situation is applying to all stbs
Username: Ke5aqn
Post Number: 2256
um ok
If you mean our forum we cater to all users no matter what receiver they have.
Post Number: 126
no i mean future-fta, the irc channel and the coders "blacklist" are all the "official" unofficial site for pansat bins and news.
Username: Ed_zackary
Post Number: 535
Bin FREEZING
Post Number: 536
BIN FREEZING!!
Post Number: 537
