Nalin, anyone? Views@t xtreme help please.
Username: Nub2fta
N/a, N/a Canada
Post Number: 81
... just got xtreme file over at total ( http://d3.b8.344a.static.theplanet.com/index.php ), for some reason loader2 will not load file. Have you heard this before??
using:
Loader2
file is labeled - DBPSW-071222X.PGM = 1388kb
tried a few times now, in a constant state of either sending or re-sending ZRQINIT is that normal? I do not think that i killed the unit as I can still view ch 100, other ppv directory & nag channels. what could be wrong? bogus file?
nub.
Username: Domy
Post Number: 61
may be you have the wrong wire
or try turn off the STB and turn on again same time press in the loader send
ihave that issue before
Username: Ke5aqn
Post Number: 2165
your ok
is this the same cord you have used before?
if so....did you try rebooting the host computer then trying again?
if that did not help what is your
OS on the host computer?
Username: Nub2fta
N/a, N/a Canada
Post Number: 82
... someone said that I should re-install the factory file. to me that makes some sense.
even the factory file will not load...
host is a xp box.... I gonna reboot it to get a fresh start.
nub.
Username: Ke5aqn
Post Number: 2167
what is nub
is it the same cord you used successfully?
what i think is happening is the computer and the stb is not talking
let me know what happens after you rebot it.
Username: Hardrockstriker
Post Number: 1013
Is your comm port set correctly?
Username: Nub2fta
N/a, N/a Canada
Post Number: 84
FTA TESTER .... worked... gremlins in the machine. I guess, a reboot was in order. now I face the freezing that everybody else is... guess we should be getting an updated bin in the near future? much better than nothing... anyways, big up, to the coders, this was looking pretty bleak until today. thanx.
nub.
Username: Ke5aqn
Post Number: 2171
Glad it worked out......again it might be silly question what is NUB?
Username: Nub2fta
N/a, N/a Canada
Post Number: 85
ohh.... sorry, nub = as in noob.
too lazy to type an extra letter when I signed up a year ago. lol. besides, it looked cool at the time.
nub.
Username: Ke5aqn
Post Number: 2177
LoL I had surgury yesterday on my arm so typing with left hand and taking pain pills....i am still lost on what NUB or noob means?
Username: Nub2fta
N/a, N/a Canada
Post Number: 86
nub = noob = newbie = novice, to the world of fta.
nub.
Username: Saqeeb9000
Post Number: 1023
try [link removed]
and download from there........let me know if it works..
Username: Ke5aqn
Post Number: 2180
sada,
who are you posting to? the user here rebooted the host computer and everthing worked. He thanked me and it was over.
