Signal Help
Username: Dcbarbera
Post Number: 8
I have 2 boxes, both xtremes
my upstairs box gets TBS ch 139 and MASN ch 432 but my downstairs box when I go to those channels says searching for signal and the channel doesnt come thru.
Both are hooked up to the same dish so Im wondering if anyone can help me with what it wrong with my downstairs box/ signal.
Both have same antenna set up
LNB On
LNB Type OCS-DP
LNB Freq 11250
22 khz off
TP Freq 12224
Diseq Port 2 for Echo 7 119 and port 3 for echo 8110
Motor Off
Legacy SW None
Username: Donnie1973
Post Number: 2010
disecq 1=119 2=110
any other sat is on 3
Username: Ke5aqn
Post Number: 1130
is it a dish 500?
Username: Dcbarbera
Post Number: 9
Danetn
so port 1 for 119 and port 2 for 110?
and yes FTA, dish 500
Username: Ke5aqn
Post Number: 1132
nope for a dish 500 one of them is no switch and one you set for the switch....
Username: Dcbarbera
Post Number: 10
all good now
thanks!
Username: Ke5aqn
Post Number: 1135
no prob
Post Number: 2012
That doesnt work... dishpro for dn 119=1 110=2
I just tried it both way 119=off 110=1 or 2 no good
119=1 or 2 110=off
no good
Dont u have a motor?
Username: Ke5aqn
Post Number: 1141
I think its a tone burst that helps with that dish 500 it should be a option in your diticq switch settings.....the trouble here is that LNB is not FTA friendly. I have heard some have to connect a old DN receiver to the lnb as well to get the correct voltage to that switch inside the LNB....keep playing with settings likke the tone burst and you may get it...
Post Number: 2014
the dishpro lnb is VERY friendly, u must be thinking of the dishpro plus lnb. That one is tricky with the pansat 2700's i know, but works fine with the vs.
Post Number: 2018
mine works fine, i was testing the info u gave that other person, thought u knew something i didnt
Username: Ke5aqn
Post Number: 1147
oh ok dantetn I can see that now clearly by rereadeing how easy it has been for that user to get it to work........
Just because your little set up works does not mean it will for them. One of the most frustrating things to hear when somthing is giving you trouble is "well it works great for me" or " I had no trouble with it" that does not help.....I am here spending my time to help others not be frustrating..
Post Number: 2020
lol, chill out dude...
I am just telling u u gave her wrong info. It wont work that way... I am telling u this so u wont tell others to try something that doesnt work. And my little set up is the ONLY set up with a dish pro lnb getting 110 and 119.
Username: Kingsatman
NYC, NY
Post Number: 95
Since October 2007
DN have been sending ECM codes that causes conflicts to 110/119 polarity or any 2 sats connected on a generic switch
I have been experimenting with various switches
Many times even if got right keys
It forces autoroll search to VS
Part of the hardware ECM
Many VS receivers will face this issue
I don't have a motorized dish
But same (one byte code) can cause motor to point to wrong sat (VERY NASTY)
Username: Ke5aqn
Post Number: 1150
I was referring to your set up as little compared to a motorized system you know 2 sat against over 20........
thanks for the info King interesting...
Post Number: 2022
anyway, maybe u should read up on the "little set ups" before u help people with them.
king, other recievers do that too as long as The channels are already scanned in. Its not a target on vs
Username: Ke5aqn
Post Number: 1154
I have a dish 500 up and working good its for my bedroom receiver....thats how i got it to work with the tone burst option so I shared that with the user.
Username: Pulp_fiction
Post Number: 349
Since October 2007
I'd say it's about time you start backing all these allegation up.
1) how is DN accessing the flashrom on the viewsat to modify it to process these ECM.
2)can you produce a decrypted stream capture
with specific system calls proprietary to the
viewsat to back this up.
Post Number: 2023
FTA, a dish 500 can have ANY lnb's on it man. They dont come standard with one or the other.
