11, 119, 129, and 61.5
Username: New_member098
Post Number: 22
Experts, I'm trying to get 110, 119, 129 and 61.5 sats with 4 lines (receivers) output so that I can watch any channel from any sat from any one of the 4 rooms. To make things little complicated I need to combine signal from local HD antenna (Trek55) so that I can watch local HD channels.
What will be suggested configuration? Your expert opinion is appreciated. LK , King any one?
Post Number: 23
Any one, who can answer this? What DISH, Which DiseqC switch, multiswitch, diaplexer I need to use to make this work the way I want.
Currently, I have one 4*1 DiseqC, one 4*8 multiswitch (DTV compatible), one 1*3 local antenna line splitter, three diaplexer to join antenna signal with DN signal, 1 DTV slimline DISH with 4 lines, 1 DTV phase 3 dish with 1 line. Can I reuse any one of the component?
Any one LK, King, Nalin, SatScanner, RTAP???????????
Username: Ke5aqn
Post Number: 914
Is putting up 4 dishes with motor's and universal LNB's doable for you? Just getting 4 out of the 17 sat's I can get here with a motor and LNB that receives both DBS and FTA is making you miss out on ALOT of good channels.....
Username: Hshunda
Union city, Ca Usa
Post Number: 8
how i can get 154 NFL channel
Username: Ke5aqn
Post Number: 915
Now in order to do what you doing it will take some work.
It is hard to get DN or DTV switches to work properly with a FTA receiver. You usually have to have a old DN or DTV receiver connected as well so the correct voltage will be sent to the switch. You could loop from the 1st receiver to the next and so on......but, the trouble will be only one receiver can control the diseqC switch so all receivers have to watching channels on the same sat. It MAY be able to be done the way you want but it will be a fight.
I can help ya find "deals" on the proper dish, motor, and LNB's if you want most sellers will give a deal when buying more than one so it wont be that bad...takes no time to set up its easer than all that switching you have already done...I just today set up a viewsay plat, dish, lnb, and motor it took 2 hours to run wires, install the dish to pole, and put new bin and channel list in the receiver, then point the dish...easy
Hope that helps ya
Username: Ke5aqn
Post Number: 916
Harminder,
Please start a new thread with new questions next time.
154 is easy its on echostar 7 at 119W
I am watching the game now HOU 10--CLE 7
Username: Rabaab
Hello
I have fortec CLASSIC NA receiver.
Can anyone tell me do you get dish channels(international channels)in this receiver
Thanks
Username: Ke5aqn
Post Number: 917
Rabaab
Post Number: 24
Let me ask my question in parts -
Here is first part --> Which dish I should use in order to get 110, 119, and 129 with 4 lines of output for 4 receivers?
Username: Ke5aqn
Post Number: 922
well ok
You cant do what you saying if i understand you right
you can find lnb's with 4 outputs and have 3 dishes pointed...Give me a min I will make a digram of that for ya....stand by LOL
Post Number: 26
Can I get atleast 110 and 119 with two Dual LNB that is 4 wires in all that will feed a 4*8 multiswitch?
Username: Ke5aqn
Post Number: 923
is the dual LNB a dish500?
Post Number: 28
That is my question? Which Dish can give me at least two sats 110 and 119 with 4 wirers in all? Currently, I have a DTV slimline that give me 4 lines that goes to 4*8 multiswitch so that I can get both sats up to 8 rooms simultaneuosly. The problem is with slimline DTV dish I can only get 110 or 119 not both.
Username: Ke5aqn
Post Number: 924
the way those dual lbs work ( at least the dish500 I know for sure) is they have a switch inside the lnb so i dont think you can use them with 4 different receivers...you will have to have different dishes or at least lnb's pointed for each bird you want to get..a mulitswitch can be used to make a lnb go to more than one receiver....their is a dish-lnb set up that can get mutilaple sat's using one dish very hard to point I have heard I always just use a dish and motor
Username: Tapeman
New York City in-HD, NY
Post Number: 1833
DTV 3 LNB picks up only from 2 side LNBs
The middle LNB does not pick up more than one or 2 TPS
DTV TPs are designed different from DN TPs despite similarity in their same polarity
The problem is a switch block in circuit board
Username: Tapeman
Post Number: 1835
6x8 Switch
Or Cascade your own like this diagram
Username: Tapeman
Post Number: 1836
This is an easy setup for 5 Sats:
22KHZ OFF to first 4 and 22KHZ ON to #5
Username: Pannu16
Post Number: 541
king is right!! U can use DP34 switchs and 3x4 switches need power too so u gotta get one with power!! I have exactly same setup~!!!
Username: Tapeman
Post Number: 1837
This is also an easy 8x1 Switch setup
Sats 1 to 4 select 22KHz ON
Sats 5 to 6 select 22KHz OFF
If this doesn't work try:
Sats 1 to 4 select 22KHz OFF
Sats 5 to 6 select 22KHz ON
Username: Tapeman
Post Number: 1838
4x4 multiswitch
Is for 2 satellite connecting 4 recivers
Username: Tapeman
Post Number: 1839
I found this link on yahoo
Great source for switches
http://store.high-techoffice.com/samu.html
Username: Tapeman
Post Number: 1841
SW-64
SW64 Automatic Multi-Dish Switch - Three Dish Four Receiver Automatic Dish Switch - connect up to four receivers to two or three dual LNB dishes, or to one DISH 500 dish with two dual LNBs and an additional dual LNB dish. Uses include adding another dish to an existing DISH 500 system for reception of foreign or HDTV programming.
BOX SW64 Switch. This switch will allow you to pick up 3 satellites. (119, 110, and 61.5 or 148)This switch will work with ANY model Dish Network receiver. Uses SW64 switch, Power Inserter, Power supply.
Username: Tapeman
Post Number: 1842
DP34
This Switch Combines 3 Orbital Locations to power 4 Receiver Outputs
-Three inputs to capture signals from three satellite orbital locations (61.5°, 105°, 110°, or 119°)
-Four outputs for connection to four receivers,
-Three direct feeds to connect to other DP34 switches.
-Up to three DP34 Switches can be connected to run up to 12 receivers.
-Switch is usually powered by receiver.
But may require additional DC power Source.
Thak yo Pannu
Username: Tapeman
Post Number: 1843
SW34
Allows you to receive signals from one satellite and Local TV antenna, combining them and connecting up to 4 receivers.
Works for all satellite system, e.g. DN, BEV system, DTV, and StarChoice, etc.
No power supply is required as the IRD's voltage is passed to the desired LNB.
Username: Ke5aqn
Post Number: 926
All those switches and you still only get what 3 or 4 sat's? I get 17 sat's with ONE dish......
Username: Tapeman
Post Number: 1844
Fo more cool switches click here:
https://www.ecoustics.com/electronics/forum/home-video/322149.html
For Over The Air Antenna (OTA Antenna) Click here
https://www.ecoustics.com/electronics/forum/home-video/330353.html
Username: Tapeman
Post Number: 1845
I'm giving different choices
Sometimes these multi receiver switches don't work with certain Satellites or combination of selective ones
I personally like to cascade my own
I don't like motor at all
I can't stand the delay for channels search
Username: Ke5aqn
Post Number: 928
so just wondering what would be the end cost on that set up to get all 17 sat's?
Username: Ke5aqn
Post Number: 929
I found that dish wf-t90 and based on prices on that site HERE I come up with around $480.00 to get what I am getting and I spent $100
nice to know
Username: Ke5aqn
Post Number: 930
Wait...I forgot all the switches to get the receiver to "see" all those LNB's
add what another $100-200? to make it $580 or $680 compared to one dish, one motor, one lnb...$100
Username: Tapeman
Post Number: 1847
Right
Yo a got a motor $50 and $50 dish
I spend about $50,000 on electronics a year
In 1990 to 2001 I spent about 1,000,000 USD on electronics
Electronics Hobby to me is Priceless
Username: Ke5aqn
Post Number: 931
I am a ham so we tend to make antenna's so I made a dish I found work fine..it did need a motor and a lnb I traded for the motor and bought the lnb so yes I have around 100 in my system..including receiver..some of us dont have unlimited funds for toy's I live in the real world with kids, bills, mortgage and other hobbies to pay for as well...
Username: Tapeman
Post Number: 1849
Anyway
The main question is...What would yo do for 4 receivers?
Username: One_eye_jack
Post Number: 33
Boy I would like to see a house with 8 dishes
It would be a sight to see.
I would think parts of North America wouldn't
allow that type of installation.
Jay keep in mind only few will try.
Even most of the the Pros will not install
a motorized system. I have called few installers
and I was told they didn't know how or had the time to mess with it.
Well I gave it a shot and now I can scan in little over 1,000 channels. I really had no
choice. It wouldn't be fair to my wife or my neighbors to install 3, 4, 5, 6, 7, or 8 dishes
on my roof.
Username: Tapeman
Post Number: 1850
8 Sats in many cases don't require 8 dishes
For example 110/119/121 or 118 can be one dish
82/91 another dish
61.5 and 77 one dish
129/127/123/121/101/97/93/45/30 can be all on one motor dish
With 4 dishes yo can own entire sky
Username: Ke5aqn
Post Number: 937
I have installed or helped with the install of several sat systems. I have had 10 foot dish, had at one time 4 dish500's on poles...the 31" on a pole with a motor is the easiest to install of all of them....you point it south, set the tilt using settings easly found on the internet, and usually the sat's just come right in using USALS in the receiver menu....the last one we installed took about 2 hours from unboxing the dish to scanning the birds.....we got 12 sat's..
Username: Tapeman
Post Number: 1851
I understand
Multiple receivers situation
What would yo do if yo got multiple receivers and want to watch 2 different programs from different satellites at same time?
This is the original question to this thread?
Motor is not an option to standard service to Star Choice, BEV, DTV or DN
The right way is fixed dish and multiple LNB and Switches
Motors good enough for one receiver, one Satellite at a time
Yo pick what is best for your quest
Post Number: 29
Having motorized DISH option is good and I would explore it in more details later, but for now I'll go with two DISH each with dual LNB feeding to a 4*8 SWA48 switch with 4 line of output for 4 rooms (I need to test if this switch can work with DN). I'm planning for 1st dish to point to 110 and second dish to point to 61.5. I think they have enough channels to engage me.
Post Number: 35
Mr. King
Yes you can watch 2 different programs from 2
different satellites at the same time.(Echo 7 & Anik F3) (Hispasat 1C and 1D)
(Rainbow 1 and Echo 3)Untrue on a motorized system you can connect more that one receiver.
Only the main receiver will control the motor if
you know how.Needless to say the rest of the receivers will only receive the channals of the
bird that main receiver is set on. BetweenEcho 7 and Anik F3 there is over 500 channels
for a family member or guest to choice from.When lot of people check into a Hotel or Motel
how many channels do you think they have to choice from.
BTW if Charlie & Bev turn the lights out,
how much work will it take to move and add dishes for these FTA Satellites Mr. King?
Post Number: 30
So what one might have to do to install motorized DISH? Which receiver and what kind of wiring (cable and Switch) will work for this setup? Do we have a installation guide or manual for such installation in forum??
Username: Ke5aqn
Post Number: 938
The best set up would be a 31", the QDH-031 LNB, motor, and one ditic switch mounted on the dish pole for each receiver. Cost of each dish is "around" $150. The disc switch you will need should have came with your receivers so you should have those right?
Set up would be easer than trying to get 4 receivers to use the same dishes.
This set up would get you ALL the sat's FTA and DBS so you would ALWAYS have TV even when DN and BEV are off...
Post Number: 38
KING TAPMAN
What was that you were saying yesterday
about the motorized dish? I have close to a 800
channels to watch free of charge How many do you have?
Username: Manusharma
Post Number: 11
Quick Q...
If I have a dish pointing to 110 , can i replace the lmb with a dual lmb and get 119 as well without physically moving the dish?
thanks
Username: Nydas
Post Number: 5336
You can put a second LNB on a bracket for 2 LNBs in front of a 20" elliptical dish. You can also mount a Twin LNB, which would scan 119W and 110W from a single LNB, but with FTAs sometimes you have headaches trying to set them up.
The word dual LNB implies a single LNB with two outputs of same sat for two receivers.
You can mount two duals on a single bracket in front of a 20" Elliptical - Each dual will feed two receivers so you can get 119W and 110W on two receivers through two switches.
Post Number: 12
Thanks Nalin
I could use a Twin LNB for the 110 and 119 but would i need to move the sat or allign it differently...it is currently pointing towards 110
Username: Nydas
Post Number: 5339
Probably minor adjustment. A bracket and a dual 119 LNB would be a better choice with a 4 to 1 DiseqC switch.
Username: Nydas
Post Number: 5340
Manu Sharma : If you were thinking of getting 118.7 Anik with all the Indian channels, it is a special 119/118.7 LNB (about $20)and a 30" dish is required.
Username: Ragi48
Flushing, New york Usa
Post Number: 16
Hello Nalin:
What is the special LNB you are reffering to for 119/118.7 satellites.
thanks}}}
Username: Nydas
Post Number: 5358
Mike Reddy:
http://www.partsforhdtv.com/lnb-circular-dss-10750-11250-c-81.html?gclid=COLtq4W ng5ACFQltZQod8TDDtA
http://www.usedottawa.com/classified-ad/4408471&category=tvs
All dealers tell me that although it is KU band, you need 30-33" dish.
Username: Tv906
Hello helpers,
Is there any kind of LNB (uninversal LNB) which can gets multiple types of signal from difference satellites?
***For example: use 1 dish, 1 LNB, + motor to get DN channels and a FTA channels like from EchoStar, AMC and IntelSat (the point here is only use one LNB and motor)
I appreciate your help and infomation.
TV
