Bronze Member Username: CailoPost Number: 28 Registered: Aug-07 | Now, this is happening more frequent. 110 and 119 are working fine, but 120, including Int'l channels are not working? What is the deal now? Is there a new code to resolve this issue? Nothing happening at TOTALFTA. Thanks |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1874 Registered: Oct-06 | 121 partially moved to 118 Get a $40 Universal Circular LNB and a slightly larger dish to get all 3 again |
Bronze Member Username: VittuPost Number: 48 Registered: Oct-07 | King Tapeman: Can we use Dish SuperDish 121 Antenna with Universal Circular LNB? |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1875 Registered: Oct-06 | yes 2 LNBs for 3 Sats (110/118/119) 1- Standard Circular for 110 1- Universal Circular for 118/119 |
Silver Member Username: DureMississauga, Ontario Canada Post Number: 140 Registered: Jun-06 | 118,119 International channels are working? |
Bronze Member Username: BruceleeBeverly Hills, California United States Post Number: 96 Registered: Mar-06 | How about 61.5 Echostar 3? That seems to be down also. |
Gold Member Username: NydasPost Number: 5313 Registered: Jun-06 | There is also a ECM going on. wait till this is sorted out before asking further help. |
Bronze Member Username: CailoPost Number: 29 Registered: Aug-07 | So I am pointing at 121, with SuperDish. Autoroll is on, but didn't say channel not found, so I am not sure if channels are moved? If so, to what Dish so I can scan it again. Is there a new code for these channels? Please if you respond, explain further instead of appreviations may be only known well by you |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1026 Registered: Sep-06 | New Key's is NOT the issue here today people...if you are getting all channels except PPV, PURN, ethnic, and Most Movie channels then you have the newest key's....... ALL RECEIVERS VIEWSAT,PANSAT, ALL CLONES are in need of new bins....as soon as the new bin's are out we will post the links |
Gold Member Username: NydasPost Number: 5359 Registered: Jun-06 | Sadi Demaro: 121 channels are moving or moved to 118.7 Anik. |
Bronze Member Username: CailoPost Number: 32 Registered: Aug-07 | Where to find 118.7? I know there is 110 and 119, but I am unaware of 118.7? It looks too close to 119, so I will give a try and scan it, since iam pointing to 119 Thanks |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1029 Registered: Sep-06 | Sadi, what LNB do you have? it takes a liner not circular like for 119 |
Bronze Member Username: CailoPost Number: 33 Registered: Aug-07 | I have the double LNB ( to get 110, 119)..I don't know exactly if it is linear or circular. Many thanks |
Bronze Member Username: Falcon21Van, Bc Ca Post Number: 16 Registered: Aug-07 | there are no 118.7 on the sat list of VS ultra. any idea how to add it? 118.7 and 119 is so close I don't know how will the LNB tell the difference.. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1034 Registered: Sep-06 | is your antenna a dish 500? In my plat i have to add it in the channel scan menu not sure if the same on yours Falcon...you also have to add the active transponders use lygnsat to look it up... |
Bronze Member Username: Falcon21Van, Bc Ca Post Number: 17 Registered: Aug-07 | Cool thanks, but I think we still need the new bin to receive the pictures right? |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1035 Registered: Sep-06 | ya right now you could get the sat but, no pic on ethnic channels MUST have a liner lnb like for example for true FTA a lnb that gets 119 will not get that sat |
Bronze Member Username: Taku420Post Number: 24 Registered: Jun-06 | Hi I have superdish-121 (121,119,110). Now the Int'l channels are moving or moved to 118.7 Anik; what changed do I need to do to my superdish 121. Do I need to buy a new LNBF? Do I need to set the angles again? If I need to buy a new LNBF, can you please provide the link or a picture or a model? Thanks, T |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1037 Registered: Sep-06 | I would recommend the best set up is, 31" dish, QTH-031 lnb, and motor. Cost is around $150. Set up is easy as pie. That way you would receive all sat's not just 3. Their are 35 sat's you could be getting..... |
Gold Member Username: NydasPost Number: 5366 Registered: Jun-06 | I have been told but can't confirm fully that a minimum 30" Dish is must for the ANIK/Echo7 combo. http://www.partsforhdtv.com/lnb-circular-dss-10750-11250-c-81.html?gclid=COLtq4W ng5ACFQltZQod8TDDtA http://www.usedottawa.com/classified-ad/4408471&category=tvs |
Bronze Member Username: Taku420Post Number: 25 Registered: Jun-06 | Ok.. lets say I buy one of those LNBF which outputs for (118.7,118.8 and 119), All I need to do is to replace the new one with the existing 119 lnbf. RIGHT?? I dont need to buy another dish, Do I? Isn't the superdish 30" wide? Plz advise. Thanks, T |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1041 Registered: Sep-06 | I am not sure what LNB will fit easly on that dish mabee another user will know... |
New member Username: Shopfree4pcPost Number: 1 Registered: Nov-07 | Here are some example pictures of how this can be done with superdish!!! [link removed] |
Bronze Member Username: CailoPost Number: 34 Registered: Aug-07 | One thing will be highly appreciated. How to add 118 to VS, or other recievers? |
