Fix for SATPRO and BUZZ out
Username: Dghumman
Ontario Canada
Post Number: 165
the fix for satpro and buzz has been out since yesterday, these receivers came with a fix now others should follow,where are the leaders they will follow soon have patience.
Username: Dghumman
Ontario Canada
Post Number: 168
when little know receivers have come out with a fix within few hours why are big name leaders taking so long to come with a fix, is someone knows please answer
Username: Aks3574
r u sure their fix is out ?
Username: Dghumman
Ontario Canada
Post Number: 169
yes i am sure
Username: Pannu16
Post Number: 594
those fixes dont work!!
Username: Ke5aqn
Post Number: 1113
"these receivers came with a fix now others should follow,where are the leaders they will follow soon have patience."
FUNNY the "fix" they have or had is a temp just going back to the old ecm ( 101 ) as I understand it.....so they are not the first to get this new ecm solved at all....also funny not a one user of those boxes is in here comferming they are working...
