Damdoom I've found the solution
Username: Lovadnun
Post Number: 34
If you still need help with loading let me know
Username: Lovadnun
Post Number: 35
Many thanks to SZOT.
Username: Heyhowru2004
Post Number: 87
Deri A,
can u tell me how to load the new bin to pansat 2700 A. I have the null modem...when i hit download it stays at 0...its says downloading but stays at o...please help
Username: Lovadnun
Post Number: 40
Hey joe...you have to change the port number
Username: Lovadnun
Post Number: 41
STEPS
#1. Make sure your USB to Serial Cable is compatible with your operating system.
#2. Connect your cable, install your drivers FROM a provided CD or from the manufacturer website and then make sure you have your drivers properly installed by checking the device manager.
#3.
- Go to Start - Control Panel - System - Hardware
- Go to Device Manager and Ports and see what Com your USB cable is set to.
- The Advance button will allow you to change the port. Change it to 1, 2, 3 or 4.
- Also be sure to change the Baud (Bits per second) to 115200.
#4. When using a loader from your specific reciever, make sure the COM port selected on the loader corresponds to the com port you changed in the previous step.
#5. Load your file.
Username: Lovadnun
Post Number: 42
Let me know if that helps you
Post Number: 96
sorry i dont understand what u mean?? there are four ports on my pc...1 and 3 work...i tried both but both stays at o..do i have to change port number on my pc system/hardware.
Username: Lovadnun
Post Number: 43
okay insert you usb and make sure its installed properly
Post Number: 98
ok i'll try that...thanks Deri
Username: Lovadnun
Post Number: 44
Then go to the Start menu, select Control Panel, System, and then Hardware
Post Number: 99
i dont have a usb...its a null cable....female to female
Username: Lovadnun
Post Number: 45
Then Go to Device Manager and Ports and see what Com your USB cable is set to. Mines was set to 10 thats why i was getting 0%
Username: Lovadnun
Post Number: 46
okay so still check the ports.
Username: Lovadnun
Post Number: 47
When you get to the proper port you have to right click and select properties
Post Number: 100
ahhhh it worked.....thanks sooooo much buddy....thank you.....thank you...i been trying to fix this for weeks...thanks again
Username: Lovadnun
Post Number: 48
make sure you also change the Baud (Bits per second) to 115200. Then it should work
Post Number: 101
deri,
i want to write the steps down for future use...can u please tell me what's the next step after right click and select properties...thanks again buddy
Username: Lovadnun
Post Number: 49
No problem...also remember the channels will have a tendency to scrammel or wait for picture.....just input 8282 then select set default...it'lll come on eventually. Just be patient.
Username: Lovadnun
Post Number: 50
just change to a port number that you want to use....preferrably 1-4, because most will say "in use". Then you change the Baud (Bits per second) to 115200 and click okay. from there you can just load your bin. Just make sure you click the back switch and write bin at the same time. Feels great doing things for yourself right? Well I know I do. No more satellite man.
Post Number: 103
for future use, what's the next step after right click and select properties?? thanks
Post Number: 104
thanks a million....peace be with u...see u around in the forums...take care
Username: Lovadnun
Post Number: 51
Go to port setting and change the Baud (Bits per second) to 115200, then go to port settings and click advance...there you will go to comp port number and change to the appropriate one.
