Switch help
Username: Eclipse_the
Post Number: 21
i have a flu converted to a 2700 and using the chancey latest bin. and i can only scan 8.6 when i try and scan 7 i get dual channels. anyone know why??
Username: Heyhowru2004
Post Number: 105
echo 7....119...switch 1
echo 8.6....110...switch 2
Post Number: 22
yes i know that. even though i set the disec and i have also changed it. the reciever wont switch
Post Number: 23
i have heard of the problem being caused by the bin. does anyone know a way to repair it or do i have to reload the flash etc
Username: Zia
Post Number: 24
any one can send me a site for converting 2500 to 2700 plz send me thanx
Username: Liala_khan
Post Number: 10
get a newer reciver
Username: Brucester
Post Number: 639
liala i hope you are good at fta that is a nice ancer ill do the same for you geting back to zia rehman if this is what you want you can get files at this site [link removed] have a nice day and hope it work ok for you
Username: Brucester
Post Number: 640
sorry you will find this at that site 2500 to 2700 Conversion
Here is the conversion for converting a 2500 to 2700 via serial port.The TOOLS files contain the jvvh205 conversion file.Follow the instructions carefuly and to the letter.Once you have completed the conversion use either 211 or 213 in place of the 208 file.Do not use the 215 file posted at other sites.There were 2 released and both have been reported to contain a clone kill.The 211 and 213 files are currently working until new fix is available.
NOTE:You can only use JVVH modded binfiles once you do this conversion.DO NOT use any 2700 clone files!!
Post Number: 24
can i get any instructive help. i know its a bin problem or setting issue. i have dual lnb and i am running a 2700 that the blind scan works fine on.
Post Number: 25
can anyone give me some useful help?????
Username: Kj101
Post Number: 16
Go buy a decent receiver
