Flu help
Username: Sk7499
Post Number: 34
hello i loaded this bin for my flu/pansat 2700 conversion x87bl-071122_b75_224 it worked fine for 5 hours then the box turned off now when i try to turn it on nothing box display is black did the box fry out any one else havin issues thx
Username: Satgrl
Post Number: 615
yup u fried it:-(...must jtag now
Username: Sk7499
Post Number: 35
how do i jtag it are the istructions is it hard thx
Username: Vittu
Post Number: 36
Did you load this file?
CS_224T_Light_100t_series_ serial bin FLU & 2500 to 2700
Username: Satgrl
Post Number: 617
DISH i think u used the wrong file...u need to use jvvh conversion files..not x87bl..thats what i think
Username: Sk7499
Post Number: 36
no i loaded the one above i know the one your are showing me is chanylands which is a real good file but the one i loaded is x87bl-071122_b75_224
Username: Sk7499
Post Number: 37
satfrl is there a way to undue the changes i made i think i goofed up it did for for like 5 hours
Username: Satgrl
Post Number: 618
that looks like the original pansat 2700 file..u did the wrong one..u need jvvh file...here is the link learn to jtag from..
http://www.dsscommunity* com/forums2007updatednewurl/viewforum.php?f=35
replace the * with a .
Username: Satgrl
Post Number: 619
yes u can jtag it with a jtg wire...
Username: Satgrl
Post Number: 620
https://www.ecoustics.com/electronics/forum/home-video/406061.html
read that thread...
Username: Sk7499
Post Number: 38
are there any instructions on how to do this thx
Username: Satgrl
Post Number: 621
AV
Username: Asharfi
Post Number: 1452
Posted on Friday, November 16, 2007 - 11:18 pm:
Hello, friends!
If you need a JTAG kit for Pansat 2500 or its clone, such as FLU, please download it from www.dssworld.co.nr. I've posted the JTAG kits for both units with easy to understand instructions. If you need it or not, please download it because a lot of people ask for JTAG kits when they end up killing their receiver. It's there for all the newbies and I'll help you out if you need any help.
Username: Satgrl
Post Number: 622
yes u must download the kit that is provided in the post above...look for it in that site..do u have the jtag wire u must purchase that
Username: Sk7499
Post Number: 39
what kind of wire is it can u let me know is it a rs232 or a parellel printer wire would radio shack have it or do i make one myself
Username: Satgrl
Post Number: 626
radio shack has it its a jtag wire thats all i know..
Username: Sk7499
Post Number: 40
one more thing to download the jtag kit which one is it fortec lifetime ultra or pansat 2500 cause the flu was converted to a pansat 2700 with the bin firware right thx for your help appriciate it
Username: Satgrl
Post Number: 627
ummm i don know for sure because i havint ever jtagged...so i dont wanna show u false info...im not sure......all that i knew i showed u lol...dont know how to jtag or anything more den that
Username: Sk7499
Post Number: 41
thx ill give it a try anyone else know how to jtag pls
im electronic savy so let me know if anyone can assist thx
Username: Nydas
Post Number: 5156
DISH: You said:
"hello i loaded this bin for my flu/pansat 2700 conversion x87bl-071122_b75_224 "
You put in the BL file for original Pansat 2700 with a clone-killer in it. You said: "the flu was converted to a pansat 2700"
You should use a flu jtag kit, but you can then do a straight load of the conversion file using:
CS_224T_FS-LifeTime-Ultra - Flash 1(29LV800BTC) - JTAG.bin
