Cool 8000 HD how do i get hd
Username: Louwho31
Post Number: 9
i have an 8000 with 154bin. i get 110-119.
after auto search i show no hd stations that i can tell. in the dish guide it says thet certain stations are hd but they don't show up. i am getting 1080i in the upper corner of my tv when i use my hdmi cable.480i when composite (yellow wire) i am setting up 129. i'm gona have to cut a tree.thanks lou
Username: Vittu
Post Number: 25
Lou: hope you have 8psk module installed..
Username: Louwho31
Post Number: 10
what is 8psk and where can i get it?
Username: Johnner
Miami, Florida
Post Number: 1319
The only channels you are going to be able to get with a Coolsat 800hd are the Nimiq2 on BEV.
http://www.lyngsat.com/nimiq2.html
Username: Rtap
FL
Post Number: 1131
With an Enhanced HD Module upgrade, the Model 6000 satellite receiver can receive more High Definition programming using new state-of-the-art satellite technology. The module installs into any Model 6000 DISH Network satellite receiver. The Model 6000u already has the Enhanced HD Module installed in it.
The Enhanced HD Module uses 8PSK (8 Phase Shift Keying) to more efficiently modulate satellite signals. Not to be confused with compression, this more efficient modulation method allows DISH Network to greatly increase our HDTV channels while using the same amount of bandwidth.
Username: Rtap
FL
Post Number: 1133
U CAN ALSO GET FEW HD CHANNELS ON DN.A COUPLE OF SPORTS.
Username: Louwho31
Post Number: 11
does the 8psk work in the colsat 8000?
Username: Mclinkus
check out ftaview.com
