Pansat 2500a
Username: The_messenger
Post Number: 70
I came across this at [link removed]
A friend gave me his 2500a(a week ago) after orasat stopped supporting. He was the one who downloaded the software, but I know it is bin 221. Well, my question is ,will I have to convert to 2700 to get new software or will they post some for nonconverted 2500a ? Keeping in mind I was strongly warned against converting it!!
No new BINs are expected for unconverted 2500s and clones.
I don't see how converting to B75 and to the current 2700 (CS_223T_Lightning) cannot work, but do it at your risk. Otherwise you can always use the receiver for the kids room or for news, i.e. for local channels
You did not mention which Bird you are watching - DN or Bev
If you have BEV the 2500a works great - use the old bin in the files section 293
it autorolls and all PPV are fine
DN I don't watch so I cannot comment on it
Post Number: 71
C/P
#1
frister
Junior Member
2500 fix
[ CS_224T_Light_100t_series_ serial bin FLU & 2500 to 2700
THIS IS FOR RECEIVERS THAT HAVE BEEN CONVERTED TO 2700
Thanks go to Chancysand for CS_224T_Lightning_100t_Series_serial
Load Chancysand CS_224T_Lightning_100t_Series_serial over any of the jvvh bins or CS_222Tor
CS_223T serial bin, I used the 2500_2700serial Loader, with box off bin in loader, then turn box
on and when it starts flashing hit write and ALL WAYS LET IT BOOT UP ALL THE WAY
but use what ever loader works for you
NOTE: AUTOROLL OFF AND STILL ROLL KEYS IN
ALSO: SAVE YOUR CHANNELS BEFORE YOU LOAD ANY NEW BIN WITH CHANNEL MASTER & THEN LOAD TO STB AFTER YOU LOADED NEW BIN< USE PANSAT_2700 AS YOUR STB WITH CM
Thanks Chancysand
NOTE: after loading 224T serial bin and if you get scramble hit 8282 on remote and do a set key
default = A/R on bev & D/N
ALSO Thanks to Chancysand for the 224T FULL jTAG BIN for person can't load through serial
ALSO ALL LOADERs & Text IN FOLDER FILE
url]http://ftabins.net/attachment.php?attachmentid=5363&d=1195849200[/url]
