INDIAN CHANNELS
Username: Boling
Post Number: 17
Hi, I downloaded the latest BIN file for pansat 3500SD and it wiped out all my sat's and channel list.
I have scanned and cannot find any indian channels, can you please tell me what SAT I should be scanning?
Username: Boling
Post Number: 18
This is the bin file I downloaded and wiped out my data from Pansat 3500SD.
X-05BL_071116_337_api_NOCARD
Username: Thakkar2000
Post Number: 73
depends on the angle ur dish is pointed to. if tis 61.5 thn its Echo 3 for desi channels. To get list of sats back once u install the new bin u have to press factory/system reset.
Username: Boling
Post Number: 19
Do I have to setup anything in Antenna setup for ECHO 3/Ku? I have everything as default.
I currently have done default factory and have no channels.
Username: Viruscauser
Leesburg, Georgia
Post Number: 417
Who, let us have your current antenna settings. Sounds like that's where the problem comes from.
Post Number: 75
once u did the factory reset, did u get the list of SAT's back...if so, then select the sat. ur dish is pointed to and do a blind scan.
Username: Boling
Post Number: 20
This is what I have for Antenna Setup for ECHO 3/Ku default settiing
LNB type - standard
LNB Local-Freq - 10750
22kHz - OFF
DISEqC - OFF
Legacy SW - None
Skew - -45
TP - [1] 12223 V 20.000
Positioner Setting - Disable
Satelliate Scan - ALL
Once I downloaded the BIN I lost everything and had to scan SAT's but no indian channels, i'm getting all other like HBO and PPV.
Your help is much appreicated!
Username: Dure
Mississauga, Ontario Canada
Post Number: 135
Try with Lnb Local frequency 11250 for echostar 3.
Leesburg, Georgia
Post Number: 426
Who, on your Echo 3 make one change - change your Diseqc to #3. Don't worry if you see no quality, run a blind scan with that setting anyway and you should get your Hindi channels back.
Report back.
Username: Boling
Post Number: 21
Abby, thanks for your help I changed the Diseqc to #3 and it worked i'm seeing all the Hindi channels now.
Leesburg, Georgia
Post Number: 435
Thanks for the feedback. Enjoy.
