How to?
Username: Raceman24
Post Number: 33
i have two dishes one for dish and one for bev .how do i get both without unhooking one and hooking up the other ..i have try the switch that i got with my sonicview 1000 but i don't want to work right ..i have dish pro on both satellites dishes
Username: Ke5aqn
Post Number: 902
It should work like this...
One line from receiver to switch.......one to first LNB on DN (110, 119?) antenna...... one from switch to LNB on antenna pointed at (81, 91 ?)BEV.....trouble I can think of here is the tone you have to send to the lnb on a dish500 to get it "look" at the sat you want will get confused by the tone you will have to send to the switch telling it what antenna to look at I don't thionk you can send them both...........
I spent 2 day's at a customers house trying to get that SAME set up to work.....we never could so he got a 31" dish and a motor much easer to set up and you get SO MUCH MORE than just 4 sat's...
Tell us what you have tried and we can go from their
Username: Nydas
Post Number: 4963
If you have a Dish pro, use DP34 switch.
If you have a Dish pro plus, use DPP 44.
If using DP34, add an old useless receiver (switch on at all times at Port 1, or have two receivers always on or power toeh port1 separately.
Username: Cartier1
Post Number: 1382
roy we need some information .
the lnb on your dish: is this dishpro sigle lnb or dishpro legacy twin.???
