Hats off to u <MINGO>, luv u
Username: Poochi425
Mis, On
Post Number: 61
oh my goddddddd !!!!!!!
thanx a million, <mingo> for the latest fix for ariza700...
we had almost ya almost given-up on the fix...
i guess u were just trying to lie-low for a while and see what ppl had to say about u n' our ariza support team....
i guess playing the waiting game was a blessing.. instead of tinkering with the jtag option..
in the end thanx again from the ariza700 club
luv u budddddd
Username: Kamara
Can any one give me the New Bin for ARIZA 700. i found one but it didn't work.
Username: Lklives
Post Number: 13646
[link removed]
Fixs for the 700-750-800 include in 1 zip file from Mingo..
Username: Topy
Post Number: 9
Poochi,,,, I dont understand your post, u never mentioned that u tested this bin or not ? you should test & than thanks to Mingo or whatever.This bin is not working, there is no screen
Username: Poochi425
Mis, On
Post Number: 63
hey rk
buddy..
check my other post: "wud u believe it"
i gave details about the bin's working condition,
it runs like a pro..
autoroll / ppv// international & zee sports 576 n' all that...
its a real fix for the latest dave ecm
keys roll on both dave n' bev
Username: Topy
Post Number: 10
Poochi ,,, I checked your other post earlier,,, I downloaded bin ,,, but there is no screen or menu on tv ,,, just blank screen receiver shows correct display but tv screen is just blank,, if I will not see anything on screen how I am gonna do anything,,, pls send exact procedure for downloading bin in receiver cuz I followed what is the right procedure which is not new for me but maybe you downloaded in different way,,, I will appreciate your response. Thx
Username: Poochi425
Mis, On
Post Number: 64
hi rk
where did u dwnld the bin from ??
its all in one package
bin300
and u have to use the loader that came with the bin and just do not click any tabs i.e., i mean app+boot file or app only etc etc
just turn rcvr on and clik dwnload button thast it.
wait for the dwnld to complete 100% flash burning...
then once u get dnld cmplete msg then turn off rcvr..
blind scan sats and u r good to go.
