2500a/flu TO 2700 dishpro setup HELP
Username: Jhousman6
I just moved here and I have the dishpro dish. I don't konw what the new bin currently is for the converted 2700's and I don't have a clue how to set it all up again, any detailed instructions would be VERY GREATLY appreciated. I am lost all the way down to if I need a switch or not, and what side to hook the cable too. Thank you so much for your help
Username: Rtap
FL
Post Number: 1097
follow the first post n this thread.good luck
https://www.ecoustics.com/electronics/forum/home-video/405361.html
Username: Jhousman6
Didn't find anything there on how to set this up
Username: Nydas
Post Number: 5038
AV has detailed instructions at this site:
www.dssworld.co.nr
I have posted detailed instructions too. Go to
https://www.ecoustics.com/electronics/forum/home-video/402679.html
Record details of your current antenna setup - particully the details in the individual sats.
Look at the first post, and follow the detailed instructions. The only change would be that you should install CS_222T_lightning or CS_223T_Lightning, instead of the UKR BIN
Those instructions, when followed properly, do work. If they do not work for you, then tough luck.
In your case, when you set do antenna setup do exactly as is your current setup.
Username: Lklives
Post Number: 13767
Just run cable directly from the Dish pro plus twin LNB directly to the receiver (no switches)..U will get the 110-119 Dishnetwork satellites, if U align the dish correctly...at least channel 100 and 500 for now..
Then just add current bin CS 223, if receiver has already been converted to a 2700...rescan channels...set default key...wait 2-20 minutes while keys auroroll..watch TV
and input antenna settings after loading the CS 223 bin..
119-disque/port #1
110- #2
type -DP dish pro
freq 11250
22-off
scan -all
Username: Space_invader
Andromeda M31
Post Number: 190
Hey, LK... It's calling you...
Andromeda M31
Post Number: 191
Username: Lklives
Post Number: 13769
M31..well I'm playing golf today and boating Friday, but I can use a change in scenery to the "south"...thanks buddy....water is sure pretty there..U should be there now and not up north..
