Receiver and Dish
Username: Sara1
Post Number: 8
I want to get rid of my current receiver and dish. I have about $400-$500 to invest in a new receiver and new dish to acquire d.n. Can anyone out there help me? Also, once I receive the system, what Do I really need to do, beside installing the dish and hooking up the whole system? Do I need to download anything?
You guys have been very helpful in the past and I really appreciate it.
Username: Saqeeb9000
Post Number: 174
buy viewsat 9000 hd if u have hd tv...
if u don't buy viewsat ultra...,pro
it has good support...
i just orderd Koolsat 6100 too...its also good...
neusat is also good ... u don't need to download files...u just need internet connection and router..just plug and play and forget about the
rest.. no need to download files...etc..
use [link removed] (for koolsat)
to download files,info,etc
great websites for new and old users.....
Username: Donnie1973
Post Number: 1853
get a viwsat ultra or sonicview 4000. Dont go HD, u will spend 700 to get ANY HD channels on DN.
Use ur old dn dish if that is what u have now. The lnb might work too. On either of these recievers, u can load the new files as they come out on a USB drive, then upload (fix) the reciever using the USB drive. No need to connect to a pc.
