Chancysand's_223T_Lighting serial bin FLU & 2500 to 2700
Username: Lklives
Post Number: 13740
Chancysand's_223T serial bin FLU & 2500 to 2700
THIS IS FOR RECEIVERS THAT HAVE ALREADY BEEN CONVERTED TO 2700 CLONE
Thanks go to Chancysand for CS_223T_Lightning_100t_Series_serial
Load Chancysand CS_223T_Lightning_100t_Series_serial over any of the JVVH bins or CS_222T serial bin, use the 2500 to 2700 serial Loader or use whatever loader works for you
NOTE: AUTOROLL OFF AND STILL ROLL KEYS IN
Chancysand came through again
Thanks Chancysand
NOTE: after loading 223T serial bin and if you get waiting for keys need to reset key hit 8282 and set key default and then do scan, all is good
A/R on bev & D/N
ALSO .txt IN FOLDER FILE
WARNING: Use all files at your own risk.
CS_223T_Lightning_100t_Series_serial.zip
[link removed]
just click on the link and download the file...no registration required..
BTW...I'm presuming that since the genuine 223 and the clone 223 files have Globecast added, that this bin for converted receivers ONLY, also has globecast added, along with DN and Bev...
Username: Space_invader
Andromeda M31
Post Number: 174
Username: Lklives
Post Number: 13747
No problem..think I need a vaca to Ramey....LOL
