ARIZA 700 to Pansat 2700
Username: Nydas
Post Number: 4734
I do not know if this works or not. I have NOT TESTED it, so I cannot answer questions on it.
[link removed]
Ariza 700 To Pansat 2700 Jtag Conversion
Ok folks here is the conversion for the ariza 700 to pansat 2700...
Now it is a USE AT OWN RISK and also DO NOT PM ME WITH QUESTIONS there will be a feedback thread started for that....To start you will need the files provided in thread... Also if you not good with jtag do not try ..
YOU WILL NEED A JTAG AND ALSO A NULL CABLE TO LOAD FILES
Step 1 Read the instructions provided with jtag info.....( a must)
Step 2 when done with jtagging do not turn off machine unhook jtag
Step 3 open up gt rom loader 27.02 and load pansat 2700 factory bin..
Step 4 load the B75_m fileNow when machine done loading it will reboot do not turn off let it show 8"s goin across then stops on last 8 for roughly 30 sec..
now turn off from back and set up loader...When loader ready turn on from back and at first sign of light hit fix on loader..Do this process for all files...
Step 5 open up BL 1.3 loader and load jvvh 209 file
Step 6 load jvvh 209 file
Step 7 load on the jvvh 211 file
Step 8 load the jvvh 217 file
Step 9 load the jvvh 220 ( the whole time using the BL 1.3 loader)
Step 9 Do blind scans of sats.What u will notice is that your display shows 8's on it dont worry about it at this point just enjoy and watch t.v........And yes your ariza remote will work on this conversion......
REMEMBER READ AND FOLLOW ALL INSTRUCTIONS
Thanks goes to RBBB and the others at geeks
__________________
Username: Lklives
Post Number: 13485
why post it..if U cannot say its even safe...
Username: Jkmago
No harm in trying as otherwise too Ariza 700 is dead with no new bin coming in
Username: Poochi425
Mis, On
Post Number: 50
but i read on one of the sites that this conversion will kill your stb i.e., converting ariza700 to vortex (pansat2700a)...will kill it
can somebody confirm ???
can't we simply use our null modem cable for file / bin loading ????
where can i buy jtag cable in mississauga ???
apart form ebay...
Username: Nydas
Post Number: 4736
Those who are familiar with Ariza 700 and sites where more information is posted should be able to take over and help each other without interference.
I have already stated my input as follows:-
"I do not know if this works or not. I have NOT TESTED it, so I cannot answer questions on it. "
Username: Tehrani
Iran, Tehran Iran
Post Number: 41
D!SH 0101 - Last Update: 11/10/07 03:31 PM
00: 8A 2C 27 51 F7 4A 6A C1 DC 15 17 70 50 3A D0 4A
01: 9B BE DC 49 25 70 8D 1B 2E 48 0D 07 5D BF 1F E2 Active
Username: Tehrani
Iran, Tehran Iran
Post Number: 46
Turn on the receiver.
Press Menu on the remote
Select Parental Control
Enter i2004 as the pin
Go down to Key Menu
Leave the first option ON and change the rest OFF
Press Exit just once
Go down to Nagravision2 , press OK
Press down arrow to select Key Number 00
Press Down arrow to highlight Key Data
Enter new Key Data for Key No: 00
Key data 6F 32 9A CA CE 2E 53 D6
36 B5 D5 7F B8 33 3A 58
Press OK button on remote to store and save the changes
then go to Key Number again and by pressing right button just once
change it to 01
Enter new Key Data for Key No: 01
Key data A2 CF CB 29 FF FF A5 4B
A3 C0 FA 48 AD 39 CF 40
Press OK button on remote to store and save the changes.
Now press EXIT until you see the picture. (Exit completely out of the menu)
Enjoy
Username: Tehrani
Iran, Tehran Iran
Post Number: 51
00:8C D5 03 E6 6A 98 71 85 AC 00 D0 97 01 F8 8A 23
