Rs232 null modem cable for cw600s
Username: Ambangisssss
helloooooo....unfortunately i dont have the rs232 null cable and im trying to get one...can anyone pls tell me if one end of the cable is female and the other end for the pc is the 25-pins?..or is it both female...
sorry...quite new to this...but would appreciate any reply!
Username: Donnie1973
Post Number: 1778
a null modem cable has two female connectors.
9 pins on each end
Post Number: 1779
if u have a nine pin with 1 female and 1 male, u can get a null modem adaptor at radio shack for 10 bucks
thanks dantetn..so i guess i connect that in the back at the bottom of the pc?
Post Number: 1780
yep, it will go in only one place.
not where da printer port is tho right?...da one with the 25 pins...
Post Number: 1781
not the 25 pin connector. The male 9 pin connector. Its the only place the cable will fit into
Post Number: 7
ok thanks so much for your help! have a good night!
Post Number: 1782
u 2
your welcome
