***HELP ONCE MORE***
Username: Statboy
Post Number: 39
Ok when trying to download the latest BIN 221 (using DB9 USB cable to connect my laptop to a Null Modem cable then that cable to the receiver im trying to download it but it remains at 0%) Let me know whats up.
Username: Satgrl
Post Number: 448
u need to unzip files and make sure ur wire is working well..and also make sure if ur receuver is on...and plugged in..
Username: Statboy
Post Number: 40
file is unzipped, its plugged in and on. Do you think that the DB9 USB cable thats connected to the laptop then to the Null Modem cable then to the receiver is the problem? I checked and they are all tightly plugged together.
Username: Donnie1973
Post Number: 1754
change ur com port on the bl loader program to 4.
Try other com ports too. 1,2,3,4
U may have to close the loader after each time u change the com port.
Username: Satgrl
Post Number: 449
i think ur cableing is wrong wow thats hella weird
Username: Dude123
Post Number: 1298
ok Luke I can help you with that....just have some paitiens ok first of alllet me know if you have downloaded the drive for usb to serial adapter or not?
Username: Statboy
Post Number: 41
When i try it on com 1,2 and 4 i get a error but only on COM3 i get Downloading but it stops at 0%.
Username: Statboy
Post Number: 42
Hi One, it came with a driver (the DB9 USB and i installed it)
Username: Dude123
Post Number: 1299
ok go to your control pannel and then system
Username: Satgrl
Post Number: 452
hmm that happens for everyone than it stops...i think its ur cable..u said it was connected to null cable then to laptop why cant u just connect it directly?
Username: Statboy
Post Number: 43
yes there.
Username: Dude123
Post Number: 1301
cuz most laptops don't have male rs 232 connection
Username: Dude123
Post Number: 1302
click on device manager...do you have vista or xp?
Username: Statboy
Post Number: 46
cant connect the null modem to laptop because it doesnt have the 9 pin for it.
Username: Statboy
Post Number: 47
I have VISTA.
Username: Statboy
Post Number: 48
The One do you have msn messanger it would be easier to communicate.
Username: Dude123
Post Number: 1303
well once you are in device manager and have your usb to serial connected to null cable...just disconnect your receiver from the other end of null cable
Username: Dude123
Post Number: 1304
yes PM me your email
Username: Statboy
Post Number: 49
PM sent.
