Need Help for 148
Username: Tj07
hello,
I am new for this please help me any one I have dish network dish and pansat 2700A I want to see Indian Channel I have problame. I can not set my dish on 61.5E so I can set my dish on 148. I can get good signal for 110 and 119. so, I can watch Indian on 148 or not and also I need to know I need to change LNB for 148 or not. Please HELPPPPPPP me.
Thanks
Username: Dimwitt
Post Number: 189
this site has the channel listings,
http://ekb.dbstalk.com/dishlist.htm
61.5 , 110 , 119 , 148 all use the same lnb type
Username: Tj07
thank you for reply Dr.Tooter
Please help me how to set dish I am trying but I am can not get signal. I am getting good signal for 110 & 119. How to set for 148 please write for me Dr. Tooter.
Username: Dimwitt
Post Number: 190
you need another dish and lnb to aim at 148.
www.dishpointer.com
Username: Tj07
thaks,
I got
Address: groton,CT
Latitude: 41.344A°
Longitude: -72.069A°
Satellite: 148.0W Echostar 1, 2
Elevation: 1.8A°
Azimuth (true): 260.6A°
Azimuth (magn.): 275.0A°
LNB skew: 47.8A°
how to setup please show me. When I am set my disk on 260.6 or 275.0 I am not getting signal but when I am little gomove my disk down around 35-40 so I am getting signal for 110or 119 but my echostar receiver say that and I select dish 148 thay says this is wrong disk so please help me for step by step please
Username: Tj07
please help.
Username: Dimwitt
Post Number: 193
not sure if someone on the east coast can pick up 148.
set up the pansat for the satellite you want to receive ,menu,installtion, antenna settings , select the sat you want and assign lnb type(diseqc switch port if needed) and connect to sat dish. use dishpoiter.com set the x at your dish location and aim as shown on the site and adjust the elavation till you find signal
Username: Tj07
which satellite I need to select for 148 in pansat2700
Username: Dimwitt
Post Number: 194
Echo 1,2
