Any fix for Ariza 700 yet ? 26-10 dn ecm
Username: Poochi425
Mis, On
Post Number: 19
hi everybody
i think i see fixes for all the major players but no word about our poor old ariza700.
when can we expect to see something to that effect ???
Username: Tehrani
Iran, Tehran Iran
hi all
iam new here and i have Ariza 700.
i need ne autoroll for ariza 700.
some one can help me?
thanks alots.
Username: Asplover
Post Number: 61
Buddy you to wait as Ariza usually gets a new bin file almost after 3 weeks when all receivers have their bin file.
Right now all others have a bin so keep for fingers cross for the 1st week of Nov.
Username: Ustaad_hc
Post Number: 309
thats true.
Username: Tehrani
Iran, Tehran Iran
Post Number: 10
hi all.
what is up?did you find some things a bout Ariza700? I did not
Username: Travnik
Vancouver, British colu... Canada
Post Number: 14
I think, you should think to by a new receiver,although Ariza 700 has a nice possibilities, even better then more receivers working today. Why, I do not Know??? I have not seen a new bin from Ariza 700 for a long time..., and I think no one will see...
Username: Tehrani
Iran, Tehran Iran
Post Number: 17
D!SH 0101 - Last Update: 10/31/07 03:12 PM
00: D6 1A 24 BF EA 89 B9 29 3D 84 14 3A 30 8F A4 C0
01: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F
B3V 0901 - Last Update: 10/31/07 11:34 AM
00: 47 FB 44 74 A3 FB FC 89 D3 08 FB F3 12 FB 6B D7
01: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 B2
Username: Tehrani
Iran, Tehran Iran
Post Number: 21
Try this site for faster keys
[link removed]
Username: Tehrani
Iran, Tehran Iran
Post Number: 28
DISH 0101 - Last Update: 11/01/07 11:35 PM EST
00: 9F DE C0 DC 51 74 62 2A 48 A1 48 CA 62 10 DD 05 Active/New
Username: Tehrani
Iran, Tehran Iran
Post Number: 29
[link removed]
Username: Tehrani
Iran, Tehran Iran
Post Number: 33
1. Press Menu
2. Scroll Down to Parental Control, Press Enter
3. Press "i" key on remote, then enter pin number "2004"
4. Scroll down to Set Default Key, Press Enter
5. Scroll up to Nagravision, Press Enter
6. Press VOL Right twice, you will see Dish Network
7. Press CH Down once, then VOL Right Twice, you will now see Nagravision 2 displayed top left You are now at the key 00, Press CH Down once so you can edit the Key Data
8. Enter your new keys (write down the old ones to be safe)
9. Press Ok to store, then repeat with key 01
10. Press exit until you get back to tv, all channels will be available
[link removed]
Username: Fundoo11
Any Where, NJ USA
Try 300 bin file available in major sites.
Please note that this file will only work for 110 & 119.
File will NOT WORK for 61.5.
You have to find keys from this forum change it manually every time key change occurs.
Ariza folks are dumb they will never figure it out.
Suggestion:
Dump Ariza in garbage buy viewsat they have best support. I just bought viewsat.
Username: Tehrani
Iran, Tehran Iran
Post Number: 36
hi Fundoo do you ues bin 300?
where is the sit?
thank you
Username: Fundoo11
Any Where, NJ USA
**dsstestercom** file version for 700 is 298 remeber it will only work for 110 & 119.
Will NOT work for 61.5.
Username: Ariza
Post Number: 213
What do u get on 61.5, 110 & 119 ??
From what i know, only the western channels are working not the eastern.. thanks
Username: Ustaad_hc
Post Number: 342
}LOOK LIKE ARIZA IS GONE.
Username: Tehrani
Iran, Tehran Iran
Post Number: 37
Is there new autoroll4 Ariza?
