Pansat 2500 Night Rider Problem
Username: Ayyubraj
Mississauga, ON CANADA
Post Number: 14
Hi ! AV/LK..
I have Pansat 2500A Clone while some wrong files night rider light gone and I have only Power switch ON. How can i FIX the receiver ?
I read some post about it but could not find.Please help me.
Username: Satgrl
Post Number: 366
if u asked me i wouldve helped
Username: Ftaexplorer
Post Number: 58
A dead 2500 CLONE ? Why bother? Time for a upgrade.
Username: Ayyubraj
Post Number: 15
I will appreciate , if u can help me satgrl.....
Thanks in advance.
Post Number: 66
You got your work cut out for you, start with reading up on j-tagging clones, then the conversion proceedure.
Good luck.
Nalinonothin should be here any minute to tell u how great and easy this is to do for newbs.I recommend you spend a hundred bucks and upgrade, you be happier in the long run ,save your time and frustration. NOT worth doing.
Post Number: 67
Read , ppl's results and percentage of successes to the amount of down time waiting for bin releases and time to complete this task.
Then consider how long black tiger and jeepster have been doing these bins, and how long jvvh did them, before he packed it in.
Then deceide for yourself,IGNORE NALINNONOTHIN.
