Sats on converted 2700
Username: South2
Post Number: 37
Hi guys,
I successfully converted my patec V1 to 2700 and everything is working fine. But when i go to dish setup, these are the only available sats -110, 119, 91 and unused. Is this normal or am I missing something? By the way, thanks all of you (especially AV and LK) for your support.
Username: Asharfi
Post Number: 1184
Hey GARY,
Try loading the latest bin
Username: South2
Post Number: 38
Hi AV,
I used jvvh 218. Thanks.
Username: Asharfi
Post Number: 1187
Hmmm,
Try doing FACTORY RESET
Username: Nydas
Post Number: 4333
Menu/Dish setup/antenna setup
Ignore your understanding of the names.
Select Echo 119.
In the submenu, select DisEqc Port 1. Look at level.
If level is above 60%, look at quality. Go down to TP and go through several to see if you are seeing changes from low to high quality or if the quality remains good. Accept NO. 1 and save it
If not try same with no. 2 and so on and save it.
Now select Echo 110W. Go though the above procedure, except that you start with the next port number. So if you have save port 1 for Echo 119, start with port 2 for Echo 110W. Save if signal/quality is found.
Now select Nimiq 91W. Start with port number, one after the ones already selected. Go through the process.
If you think you have more than three sats, go through the process using "unused".
You may have to change the LNB type and/or frequency.
Exit out and do a Blind scan on each.
Then go and edit sat names if you have to, e.g. the last one I converted, I had to change the name Nimiq 91W to Echo 61.5, because that is what I was really scanning.
You can add new sats.
Username: Devenw
MISIS
Post Number: 40
HELP ME PLEASE ON THIS ONE.
I have converted my Fortec life time ultra to Pansat 2700, everything was fine while i was using last eve, when i see this moring no power on my receiver.
Your help is greatly appricated
Username: Asharfi
Post Number: 1191
If you don't see any power or light on your box, then you have to JTAG. Also, try upgrading your box to a new unit.
Username: Devenw
MISIS
Post Number: 41
AV ,
How?
Username: Devenw
MISIS
Post Number: 42
Please help me AV.
I greatly appricated.
Username: Asharfi
Post Number: 1193
How to JTAG? Well, to JTAG your unit, you need a JTAG cable which cost around $10 - $15. Then, download the Black Death Repair Kit for Fortec STAR Lifetime Ultra receivers.
Username: Devenw
MISIS
Post Number: 44
AV,
Where can i find repair kit, i just try i want be able to find any where.
do i be able to find this cable in any electronics store? (Sattelite)
Username: Asharfi
Post Number: 1198
Yep ... most of the computer hardware stores have JTAG cables ... for the Black Death Repair Kit ... ask LK .... he'll give a dsscommunity link to that file
Username: Asharfi
Post Number: 1199
OR - Try www.ftabins.net for the kit
Username: Ak2011
Need help scanning satellites ECHO 3/Ku and ECHO 7/Ku for Converted Pansat 2700 (Dish Network 0101). ECHO 4/Ku downloaded fine but have many missing. All help will be appreciated. Thanks.
