Ariza 700..can we convert this to any other receiver??
Username: Imauser
Post Number: 7
I have Ariza 700. Does anybody know that can we convert Ariza 700 to any other receiver (Like we converted FLU and Pansat 2500 to Pansat 2700 clone)??
Username: Ustaad_hc
Post Number: 312
not yet...
Username: Tehrani
Iran, Tehran Iran
Post Number: 8
hi all.
what is up?did you find some things a bout Ariza700? I did not
Username: Tehrani
Iran, Tehran Iran
Post Number: 16
D!SH 0101 - Last Update: 10/31/07 03:12 PM
00: D6 1A 24 BF EA 89 B9 29 3D 84 14 3A 30 8F A4 C0
01: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F
B3V 0901 - Last Update: 10/31/07 11:34 AM
00: 47 FB 44 74 A3 FB FC 89 D3 08 FB F3 12 FB 6B D7
01: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 B2
Username: Tehrani
Iran, Tehran Iran
Post Number: 27
DISH 0101 - Last Update: 11/01/07 11:35 PM EST
00: 9F DE C0 DC 51 74 62 2A 48 A1 48 CA 62 10 DD 05 Active/New
Username: Tehrani
Iran, Tehran Iran
Post Number: 34
1. Press Menu
2. Scroll Down to Parental Control, Press Enter
3. Press "i" key on remote, then enter pin number "2004"
4. Scroll down to Set Default Key, Press Enter
5. Scroll up to Nagravision, Press Enter
6. Press VOL Right twice, you will see Dish Network
7. Press CH Down once, then VOL Right Twice, you will now see Nagravision 2 displayed top left You are now at the key 00, Press CH Down once so you can edit the Key Data
8. Enter your new keys (write down the old ones to be safe)
9. Press Ok to store, then repeat with key 01
10. Press exit until you get back to tv, all channels will be available
Try this site for faster keys
[link removed]
Username: Fundoo11
Any Where, NJ USA
Try 300 bin file available in major sites.
Please note that this file will only work for 110 & 119.
File will NOT WORK for 61.5.
You have to find keys from this forum change it manually every time key change occurs.
Ariza folks are dumb they will never figure it out.
Suggestion:
Dump Ariza in garbage buy viewsat they have best support. I just bought viewsat.
