Pansat Clone, VS extreme
Username: Eliaselias
Post Number: 10
Nalin and LK
First i have to say thank you both you have no idea how much you are helping us with your comments and with your posts.
Second i have a question: Pansat clone 2700 i need please the name of the file. And for viewsat xtreme also i need please the name of the file and is it true that 07-10-24X IS KILLING OUR RECEIVERS yes or no.
Thank you a lot and keep us as always informed.
Username: Donnie1973
Post Number: 1406
maybe if it is a clone. I dont think it has harmed many, maybe 3 or 4. All i know are working fine with it.
look at ftaprosupport for the clone bin under pansat files. it will say clone bin
Username: Rtap
FL
Post Number: 752
hi can i be spoon feed.i really don't want to read and rather have someone else do all the work.
Post Number: 1410
yes, I can help... do u need me to tell u your name sir?
I can tell u how to get the ur local grocery store if u would like...
lol
Username: Koko_wawa
Post Number: 28
Downloaded the new bin file for VSxtreme last nite and it still works fine. If you have clone or you turned the box off prematurely and before it shows (end .. on .. channel number)then your receiver is DEAD
