Help with dp legacy twin lnb and dp34switch
Username: Satscanners
Anyone know the antanae settings for the above on echo 7 and echo8/10 with nimiq1/3 added to 3rd switch input?
With both connections from lnb to the first two ports of the switch, sets the lnb to default mode, now add a third dp duall, with one termial to third dp34 input port, what settings should be used ? On a cw600p
