8psk with viewsat
Username: Ds_edm
Post Number: 47
if i put 8psk unit with viewsat hd. Then can i see dish hd channel? and can i put any 8psk unit or is viewsat unit diffrent from other?
Username: Lklives
Post Number: 12801
yes u can...in fact...for the Viewsat 9000 HD
Dishnet HD Adaptor Is Now on Ebay
Here is the item #260170249374
Going to sell out fast - but the unit is now available!
It is in an all-in-one unit as I had previously posted. No need to buy the both the board and the adapter like the Sonicview has.
It comes with :
Turbo 8psk Adapter
1 Ribbon Cable
Power Cable
Coax cable
Washer & Nut
Username: Rtap
FL
Post Number: 598
hey LK i just check it out on ebay.this all in one is great and looks easy to install.
Viewsat 9000 HD Add-On Module
You are purchasing one (1) add-on module for the Viewsat HD 9000
This product is a single board unit, no other adapters needed.
This is everything you need to complete your HD experience!
No other adapter is available for the viewsat 9000 receiver.
This is an authentic piece.
Includes: Adapter
1 Ribbon Cable
Power Cable
Coax cable
Username: Ds_edm
Post Number: 48
thanks guys. but it is out of stock. any other adaptor
Username: Youarenumber1
Post Number: 7
LK,
how about pansat 9200hd? Do I need the 8psk module to get HD channel?
