Is anyone seeing DN on Pansat???
Username: Rolan
Post Number: 36
put in keys manually and turned off autoroll, still getting scrambled or bad channel. is anyone seeing DN?? HELP!!
Username: Dude123
Post Number: 1200
its working if you get a scrambled or bad channel msg first thing you have to do is reset your box for the back switch
here are the latest keys
D!SH 0101 - Last Update: 10/08/07 02:58 PM
00: 2E 79 BB 5B 8D CA A7 23 56 C0 21 A1 0D 90 48 99
01: 90 4E 48 12 4A 6B 33 FB A5 D4 41 32 94 DA 24 DC ACTIVE
B3V 0901 - Last Update: 10/07/07 02:29 PM
00: 9B CE 5C 9B 8B DE A5 ED 1E D3 9E 16 68 73 22 C2
01: 2B E1 34 1C 37 14 A7 D4 07 0C E7 AC D2 2F 57 2E ACTIVE
Username: Rolan
Post Number: 38
no luck, turned off back switch, all autorolls are off, rechecked keys, still no picture, scrambled or bad channel. any thoughts?
Username: Dimwitt
Post Number: 151
Try "set default key" and enter new keys
Username: Dude123
Post Number: 1203
by turning off all autorolls you mean you left the keycode on though right...make sure you have that ON everything else you can turn it off and then enter the keys manually
Username: Jorge66
quien sabe el codigo para un 3500sd hoy 10/08/07 10:23 pm gracias
Username: Kwshea
Houston
DN key was refreshed at evening again:
D!SH 0101 - Last Update: 10/08/07 07:32 PM
00: A6 09 D3 14 86 DC 86 69 49 C3 5A 9E B1 68 45 1D
Username: Lucia
Post Number: 363
yo tampoco puedo ver
Username: Rtap
FL
Post Number: 540
you need to set default key then enter keys manually.turn off autoroll.
Username: Laurad
Post Number: 30
LK Thanks for the fast keys, I am still enjoying
the Dallas/Buffalo Game. and to the Pansant
question I am seeing all chanels ok. Don't foget to set the time. also do as i did follow the instructions for input of the keys> It does work.. Again Thanks for the update
Username: Lucia
Post Number: 364
i tried everything and nothing works. is there a new bin or sumthing? thank u .=)
Username: Rtap
FL
Post Number: 542
lucia follow my instructions. i'm running fine.
Username: Rtap
FL
Post Number: 543
lucia this is how its done
RTAP
Username: Rtap
FL
Post Number: 539
Posted on Monday, October 08, 2007 - 10:58 pm:
menu
parental control
second pin 0000
set default key
niagravision 2
on 00 enter keys 86/00
on 01 enter keys 96/00
turn autoroll off
and watch tv
Username: Cartier1
Post Number: 1191
there is only something there si no bin :-)
Username: Rtap
FL
Post Number: 544
bin 331 not rolling keys.
Username: Lucia
Post Number: 365
rtap, thank you!
my autorolls were all off and before anything i turned them on, and then i followed your instructions [turned them back off at the end of course]. :-) thanks!
Username: Pssiam
Aurora, CO US
Thank you Rtap. I am new to this board. But I am able to see DN with no trouble after going thru your checklist to Luciaa.
Username: Rummage
New Bin at Future good luck
Username: Manny180
PR Puerto Rico
Post Number: 9
There is a new bin for pansat2700A in totalfta.
Was released an hour ago.
